Old 04-28-2011, 03:48 PM   #1
T Pexx
Drives: 08' toyota yaris liftback
DIY fog lights question!
okay so i followed this DIY for my 08 hatch
http://www.yarisworld.com/forums/sho...ght=fog+lights
and i think i did everything correctly because the foglights are able to turn on and switch is working fine, although when i turn my headlights on with my fog lights, my fogs turn off. then when i turn my headlights off my fogs are able to turn on. so i cant turn both on at the same time.
has anyone else had this problem or know what i need to do to fix?
please help.
T Pexx is offline   Reply With Quote
Old 04-28-2011, 05:59 PM   #2
JTDBT903
JTDBT903's Avatar
Drives: '08 SEDAN 5 SPD.
Did you try switching the wires around going to pin 3 and 4/13?
JTDBT903 is offline   Reply With Quote
Old 05-02-2011, 09:09 PM   #3
T Pexx
yes i have. any other suggestions
Old 05-02-2011, 10:50 PM   #4
The switch on the aftermarket fogs is really not designed to be used with the OEM fog light wiring. The manufacturer of yours may have changed the internals of the switch, making it yet more incompatible.
Try disconnecting the switch wiring and just jump pins 3 and 4 on the headlight stalk connector. With them jumped the fogs will turn on with the headlights if the under hood wiring is correct and the fog light relay is the correct one.
Old 05-05-2011, 06:18 PM   #5
T Pexx
^^^ so the fogs will just turn on automatically when the headlights are on?
Old 05-05-2011, 06:25 PM   #6
Yes - With 3 and 4 jumped together they will.
Old 05-05-2011, 07:25 PM   #7
JTDBT903
JTDBT903's Avatar
That is just with the low beams I believe.
Old 05-05-2011, 08:54 PM   #8
Correct - Jumped that way they will turn on with lows and back off with highs.
Tags
08', fog lights, hatchaback
Add auto on/off lights + fog lights using OEM switch inquiry? ricepower DIY / Maintenance / Service 4 04-05-2011 05:46 PM
Fog lights, or parking lights stopped working sylvermagyk DIY / Maintenance / Service 4 03-24-2011 06:13 PM
Fog Lights Poll Reeves360 Cosmetic Modifications (Exterior/Interior) 14 12-27-2009 03:00 AM
DIY needed for sedan ebay fog lights. YarisSedan DIY / Maintenance / Service 0 11-16-2009 06:19 PM
Fog lights for S sedans (US version) paeko73 General Yaris / Vitz Discussion 11 07-03-2006 12:38 AM
