![]() ![]() ![]() ![]() ![]() Drives: it is kinda stock Join Date: Oct 2010
just used meguires hot rims and armor all tire foam (not at the same time 2 different days) both of them left a white film i followed the directions what the fugg any suggestions on other good wheel stuff or why its leaving the white residue ?
The white residue on the tires is from the actual mold used to make the tire. It is a grease like substance sprayed in and then the rubber is poured. All is then sealed and heated. The mold lube allows the tire to seperate from the mold. It eventually will wear off. It is a beyotch to get off if you can't wait. I just clean with a APC and treat with Stoners. The wheels get normal wash and LSP is until I get rid of my supply, Megs NXT 2.0 sealant.
![]() ![]() Drives: 2010 5 Door Join Date: Jan 2011
Get a tire cleaner and give the tire a good scrub. It shouldn't leave a film. I wouldn't use tire shine often. Tire shine tends to dry rot the side walls of the tire over time with excessive use.
A pressure washer works great at removing anything from the tires.
Pressure washer does well. Just don't get to close with a high power one.....I know.
will try
| Yarisworld Decal -SHOW YOUR YW PRIDE!! | Astroman | Items for Sale by private party | 235 | 08-21-2019 10:45 AM |
| white yaris; white wheels? | botchilah | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 18 | 02-07-2009 10:20 AM |
| So Hasher now has a sexy ride...... | hasher22 | Photo-Video-Media Gallery | 15 | 06-09-2007 07:33 AM |
| White on white | d2dailly | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 02-27-2007 08:09 AM |
