![]() Drives: '07 Yaris Hatchback Join Date: Jul 2010
Serpentine belt broken with oil on it
My battery light came on last night. This morning I popped my hood to see that my serpentine belt was broken and there was oil on one of the ribs. There is some black oil on the side of the engine about midway down. My engine oil isn't black, it's more like a yellowish brown.
Any ideas as to the source of the oil before I call a tow truck? 07 HB btw |
Maybe it whacked something else when it snapped and came loose. Check the CV joint boots on the passenger side to make sure that it didn't whip and tear one, picking up the grease from inside of the boot.
Good call there CT. I would have checked oil level at the dipstick then looked elsewhere as in where you stated.
The rubber cover on top of the motor mount was chewed by a racoon more than a year ago, and it has been sort of half assed covered with some plastic covering. It would appear that the source of the oil is the motor mount, I believe the Yaris uses hydraulic fluid in these mounts correct?
So my guess is that the motor mount failed and must be replaced. What do you think? Engine oil level is fine, same level it was at yesterday when I checked it. I will go look at the CV boots, but I don't think that's where it's coming from. |
pictures would be very helpful
I'm having the car towed to a shop I'll let you know what they say.
As I suspected, the oil was from the busted motor mount. It will have to be replaced along with the serpentine belt.
The bearings on my water pump are also shot and it will need to be replaced. The most likely cause is when I tightened the serpentine belt myself and did not check the tension, which put too much strain on the bearings. WARNING TO ANYONE WHO FINDS THIS THREAD DO NOT TENSION YOUR OWN SERPENTINE BELT UNLESS YOU HAVE A TOOL TO VERIFY CORRECT TENSION. |
![]() Drives: stock Join Date: May 2011
hi i was reading your blog and i have a question. i have an 08 w/65k on it and it just lost the belt this morning. what is the pully belong to that is under the ALT. i have looked online for a diagram and called a few parts stores and they dont know the layout. i didnt really look because i was late for work.. H E L P please
#9 | |
thanks ctscott..
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 09:14 PM |
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 08:18 PM |
| A Mystery Oi'll Say! | Yar Is Word | Fuel Economy Forum | 16 | 05-11-2013 05:22 AM |
| Altenator Belt Broken After Replaced by Toyota | Yaris_guy | DIY / Maintenance / Service | 12 | 01-18-2011 10:14 PM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 09:16 PM |
