Old 06-13-2011, 05:31 PM   #1
Arizona_Commuter
Drives: 2007 Yaris Sedan-White
Front End Clunking Sound when hitting small bumps
This is a great forum! Thanks in advance for all your help! I attempted searching for this topic but couldn't find a good match. I have a 2007 Yaris Sedan, 60K miles. Everything suspension related is all stock. Yesterday, for the first time, I noticed a clunking sound when driving over bumps in the road, on speed bumps, the curve getting into my driveway etc. The sound lasts as long as it takes the tire to rebound to it’s normal riding position (fractions of a second). This is a new sound that has never been present before. It’s a deep grinding sound, like what I imagine a quick fart from a t-rex would sound like. (not sure how else to describe it).
Again, thanks for all your help.
Arizona_Commuter is offline   Reply With Quote
Old 06-13-2011, 09:18 PM   #2
johnny_vitz
Drives: 2005 Toyota Echo
05' Echo Hatch - Greddy Supercharger - rear disc
johnny_vitz is offline   Reply With Quote
Old 06-13-2011, 09:35 PM   #3
I was going to say a blown strut, but then you said a grinding sound (blown strut/shock would produce a hollow thump sound on bumps). Maybe it's the spring sagging and coils clattering against each other?
Old 06-13-2011, 10:19 PM   #4
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
that or a worn bushing maybe? lower/upper ball joint... confirmation anyone?
can you make the sound by pushing on the car to make the suspension compress while its not moving?
i guess if that doesnt work, try puting it on stands, then take a hydrolic jack and jack up the tire as far as it will go with out lifting it off the stands and release the jack to see if you can duplicate the noise..
please have a friend with you while doing this.
try to listen for that sound and get back with us.. if possible.. can u get a video up and let us hear it?
Old 06-13-2011, 11:51 PM   #5
Hershey
Could be related to control arm(s) . http://www.yarisworld.com/forums/sho...ntrol+arm+bolt and http://www.yarisworld.com/forums/sho...ntrol+arm+bolt . Let us know of your findings .
Old 06-14-2011, 04:01 PM   #6
Liu997
Drives: 2008 Red Yaris LB
Check the clearance of the tire. I know it may seem obvious but my yaris had some weird sound and it was actually a piece of bumper that bent and started rubbing against the tire.
Liu997 is offline   Reply With Quote
Old 06-14-2011, 07:35 PM   #7
Arizona_Commuter
Thanks guys for your help!
Kaotic – the sound could be classified as a hollow thump, I’m bad at describing noises (hence the t-rex reference).
Ilikerice – Yes, I can make the sound by pushing down on the passenger side front fender area (directly above the tire) and rocking the vehicle. The sound is made when the vehicle is at it’s lowest point and only when it’s rocked really hard.
Hershey – I thought you were on to something with your link, however, my bolts are all in tact. I’m wondering though how much the stealership would charge me to check if there’s a Service Bulletin on the vehicle (should be free if it’s a recall right?)
Liu – bumper is good, thanks
I know proper forum etiquette, when the problem is solved, I’ll be sure to close out the thread with the solution.
Old 06-14-2011, 09:27 PM   #8
Can you shoot a video of it, so we can hear it and see the motion that results in the noise?
Old 06-14-2011, 10:30 PM   #9
thepartsmancometh
Drives: '08 LB, '07 WRX
Ive had the front (rearmost) lower control arm bushings make some noise at extreme travels (like hitting a big bump, or extreme driveway angle). No excess play, Silicone shut em up
thepartsmancometh is offline   Reply With Quote
Old 06-15-2011, 12:07 AM   #10
Hershey
I would take it to a shop where they could possibly look at the control arms and front end ( struts , bushings , etc. ) for free . Best of luck and keep us updated .
Old 06-15-2011, 06:00 AM   #11
ilikerice
ilikerice's Avatar
If it was a recall, you would get something in the mail.
Service bulletins are just common issues that toyota finds regularly and is a guide to help techs to identify some quick diag. They are not a safty issue. Just common complaints that have a common fix.
Toyota will probably charge half hour diag fee.. and if they need more time they will let you know.
Old 06-15-2011, 03:39 PM   #12
Hartside
Drives: 2008 Yaris 1.3TR Hatchback
I had that on our mk1 Yaris (1999 - 2005) and it turned out to be a broken drop link onto the anti roll bar, which is a very common problem. Haven't looked under our 2008 Yaris to see if the set up is the same, maybe others can advise
Hartside is offline   Reply With Quote
Old 06-17-2011, 12:02 AM   #13
Arizona_Commuter
Problem Solved! I pulled up to my driveway today, my neighbor happened to be standing outside (he's much more mechanically savvy than myself) and I asked him about it. He had me turn my wheels all the way to the right (the noise was coming from the right side), had a look and within about 4 seconds, showed me where the nut that connects the sway bar was clinging to life by about half a thread. Tighten’d-r-up and boom, problem solved. I had spent some time down there but didn’t notice that one. Sometimes it’s the silliest things! Thanks guys for all your help.
Old 06-17-2011, 12:11 AM   #14
Congrats on solving the problem.
Old 06-17-2011, 01:07 AM   #15
auxmike
auxmike's Avatar
Good thread.
Even better the problem was solved! I'll look at mine next time I do my oil change...
Old 06-17-2011, 04:33 AM   #16
ilikerice
ilikerice's Avatar
this is one of those threads where it should say [RESOLVED] in the title now... admins?
Old 06-17-2011, 12:32 PM   #17
Hershey
Tags
bumps, clunking sound, suspension
Front end mask RocknRollRon Items for Sale by private party 7 09-02-2007 07:12 AM
Bra or front end protector? Yaris S N9QGS Cosmetic Modifications (Exterior/Interior) 6 07-13-2007 09:29 AM
FS: Extra Set of Fat Cat Front Bumps Stops Galavoxx Items for Sale by private party 1 07-03-2007 09:58 PM
FT: Polar white Front End in So. Cal Walter Items for Sale by private party 33 01-16-2007 01:11 AM
For trade, polar white front end Walter California 0 01-09-2007 12:38 AM
