Old 10-06-2017, 04:38 AM   #1
BennyLava
Drives: 1987 Silverado
Some hard starts?
Every once in a while, my 2009 automatic sedan will have a hard start. Where the car will continue cranking for another 3 or 4 seconds, after it should. But its doing this because the engine isn't starting. This only happens about once every 20 starts. But its really noticeable and I was wondering if anyone here might know what causes this. I was thinking maybe fuel pump, but this has been going on for so long now, that I assume the fuel pump would have died a natural death by now if indeed it was the problem. Then I thought maybe it could possibly be the fuel filter needing changed, but I read here on the forums that the filter doesn't really ever need to be replaced unless it clogs from bad gas and then the car just won't start.
I'd like to address this issue before whatever the real problem is, finally gets worse and I get stranded somewhere. The car just takes longer to start, but its so long that you know that there is something going wrong that needs to be fixed.
Forgot to mention, the car has 187k miles on it.
Old 10-06-2017, 05:53 AM   #2
Yaris709
Drives: 07 yaris
I've had my yaris for 2 years now and its been doing the same thing since I've had it. The starter sticks is what's happening. Wouldn't worry to much about it.
Yaris709 is offline   Reply With Quote
Old 10-06-2017, 06:53 AM   #3
dogsridewith
Drives: 2007 2-door hatchback
Random long cranking starts
Observed in different cars over several decades. Sometimes or usually in hot restarts after some period of rest. Never explained, never got worse, no confirmation in at least one web forum discussion I had somewhere.
One possibility is the engine cold-start temperature sensors not in sync w/ engine needs during heat-soak transients. Another is the EVAP system somehow sucking the fuel line contents back into the tank.
(Random long cranking starts)
Old 10-06-2017, 07:55 AM   #4
RutherfordmanX
Drives: 2017 Yaris Hatchback
The new 2017 I just got a few weeks back takes longer to start than my 2008. It is well within a reasonable time but not as quick as my older one. I do see it putting a bit more wear on the starter.
RutherfordmanX is offline   Reply With Quote
Old 10-06-2017, 11:16 PM   #5
BennyLava
Were you ever able to absolutely confirm this is the case?
If so maybe replacing the starter would fix it. I just wanted to do something in case it will eventually leave us stranded somewhere.
Old 10-07-2017, 12:12 AM   #6
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Some cars are equipped with crank and hold feature. So the computer is actually controlling the starter.
Old 10-07-2017, 02:58 AM   #7
BennyLava
That was something I was wondering about. It would help to know if my car is one of those cars. 09 automatic sedan. If my car has this, it could mean that it is not actually a starter issue, and that the computer is having to make the starter spin for longer in order to get the engine to start. Could mean there is a different problem.
Old 10-07-2017, 07:04 AM   #8
Bluevitz-rs
Simply turn the key for a second and let it go. If it keeps cranking you have crank and hold.
Old 10-07-2017, 08:07 AM   #9
IllusionX
Drives: 07 Yaris Sedan Aero
All 06+ Yaris have it. Not sure about the gen2 or gen3, but I'm pretty sure they are.
You don't even need to hold it for 1s. Just flick it as if you pushed a start/stop button.
Mine takes a tiny bit longer to start since I changed the battery. I wouldn't worry if it doesn't overcrank.
And seriously? More wear on the starter? Do you push the hand brake button as you engage it, so you don't wear the clicker?
Old 10-07-2017, 10:23 PM   #10
BennyLava
Who said more wear on the starter?
Although yes, the more a starter is used, the more wear it sees. You don't wear out a starter that never gets used and sits on a shelf.
Old 10-09-2017, 03:13 AM   #11
I know the third gens removed that feature.
Old 10-09-2017, 04:03 AM   #12
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Correct. No crank and hold on 3rd gen cars (or at least on mine).
Old 11-07-2017, 07:37 AM   #13
BennyLava
Well its doing it more and more often now. Its the wife's car that she drives to work every day. Although its also something of a shared car between us, since my 87 silverado gets a pitiful 15mpg. So I also use the car a good deal.
She's becoming concerned about it, because its doing it more and more and its doing it for longer. Is there anyone here who is really clear on what causes this?
Old 11-07-2017, 08:03 AM   #14
hairygityeti
Sir Rustalot
Drives: Toyota Yaris silver 2000 reg
Talking
I have a first gen Yaris i wounder if i have crank and hold?
But one thing i do know i have is 1st gen rustand a lot ofit! lol
If it wasnt for my modesty ,i would be perfect !
hairygityeti is offline   Reply With Quote
Old 11-07-2017, 02:18 PM   #15
dogsridewith
Crank and hold starter Toyota Yaris
Mine did the crank-and-hold thing this cold damp morning. (Short drive after dark last night.) Started fine--before enough cranks to make me concerned that something is out of tune. But I had definitely released the key. I'm not sure it always does crank-and-hold on a key turned too briefly to start...will have to pay attention to that. Interesting if it only does crank-and-hold under certain conditions.
Old 11-07-2017, 02:45 PM   #16
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
I had the same issue...every once in a while i'll get an extended crank. I disconnected the battery and it hasnt done it since.
Is it a fix or coincidence? no idea
worth a shot for y'all to try
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 11-07-2017, 03:20 PM   #17
BennyLava
I'll try the battery disconnect. Can't hurt to try that.
Old 11-08-2017, 07:38 AM   #18
dogsridewith
Crank and hold starter Toyota Yaris Generation Two 2007
Is this a problem? Or is it something gen 2 Yaris is supposed to do under certain conditions?
Hard starting when cold, runs fine Kubcat DIY / Maintenance / Service 6 01-03-2022 09:58 AM
intermittent hard starting Ramon1691 DIY / Maintenance / Service 17 07-20-2016 01:49 AM
Toyota yaris 2002 - Hard clutch abhinav_kr DIY / Maintenance / Service 10 06-29-2016 08:08 AM
yaris hard starting when hot, fine when cold ianpog DIY / Maintenance / Service 11 08-12-2015 10:24 PM
Hard braking? abdallah380 General Yaris / Vitz Discussion 2 07-26-2010 02:37 AM
