![]() Drives: 2010 Liftback Join Date: Apr 2011
pinging
So for a while now I've noticed that my engine seems to what I believe to be pinging and since it has gotten hotter out it seems to have become more pronounced as pinging does in warmer weather. I've been reading a lot on here and in general about the subject. From the info I have gathered it seems some light pinging is normal and that it is common with the Yaris and even though the manual suggests an 87 or HIGHER octane fuel the general consensus seems to be that putting in anything more than 87 is a waste of money. From what I have read the Yaris with its 10.5:1 compression ratio engine is considered to be high compression. My question is if a car such as the newer Honda Civic Si which has a ever so slightly higher compression ratio of 11.0:1 requires premium fuel then why does the Yaris only require 87?
Only Happy When it Rains
because the computer system has been adjusted for the 87 octane. But if you experience pinging on a regular basis I think you really need to find a better quality gas. I haven't ever experienced it and i only run 87.
If you want to try a higher octane, that is your choice, but you should keep track of everything while you do to see if you really gain anything for it. A Scanguage would be a great tool to help keep track of everything.
Colin Chapman disciple |
![]() ![]() Drives: 2008 yaris sedan Join Date: Jul 2010
45,000 miles and I have not had any pinging at all, I run 87 chevron or shell
![]() Drives: 2007 Blue Yaris Hatch Join Date: Aug 2007
Mine doesn't ping at all, even if sometimes I forget to downshift to first and let out the clutch with hardly any revs. But If you have a gentle throttle foot and buy crappy gas, you may have more deposits inside your combustion chambers than I do. I would stick with regular, but buy big name gas only, and go out there one day and rev the hell out of it.
If that don't work you have other problems.
![]() ![]() Drives: 2007 LB Join Date: Jan 2009
sg11, it really should not be pinging. when are you hearing this? is it just at high speed crusing? or when accelerating? or idle?
as mentioned i would get some brand name gas, a good fuel injector cleaner and add it to the tank and drive it hard to try to clean out any dirt/carbon. if that doesn't do it, you should have it looked at. not good to run lean like that for too long. |
Are you actually experiencing pinging, or is it valve tapping? These cars all exhibit some degree of valve tapping. The engines are never truly silent.
For those of you who are running on 87 with no pinging, is there ethanol blended in?
Virtually all pump gas contains ethanol
#9 | |
I hear it mostly during light throttle conditions when driving around at lower rpms or going up a hill. I always use quality gas (shell, sunoco, exxon). |
You have a 2010 hatchback, so you can't have that many miles yet. You buy quality gas. It's a Toyota and it's under warranty. Don't worry about the little sounds, it's a machine. Turn up the stereo and roll down the windows and enjoy yourself!
#12 | |
![]() Drives: 2011 3dr hatch Join Date: May 2011
#14 | |
A real way to know how reliable these cars is to go into the forced induction section and find out how many of those peep's have lowered their compression ratio. That was something that used to be an absolutely must do.
#15 | |
And as far as reliability and forced induction, did you mean to say they haven't lowered their compression ratio? |
![]() ![]() ![]() ![]() ![]() Drives: 2008 Polar White LB Auto Join Date: Oct 2008
Maybe your hearing the timing chain? It's pretty noisy on these Toyota engines.
I live my life a quarter pounder at a time. And for those 500 calories or more, I'm free. I need FRIES! Two of them. The big ones. Oh, and I need them tonight. You're lucky the double shot of BBQ sauce didn't blow the seam on your nugget box. There she is, 2 pounds of pure beef. My dad ate it in 9.0 seconds flat. Check it out, it's like this. If I lose, winner takes my happy meal. But if I win, I take the burger and the toy. To some people, that's more important. |
The more timing advance you have in the ignition the higher grade of fuel you need. The 1NZ has a very conservative timing advance compared to the Civic SI and that's mostly why it needs high octane fuel.
If you were to run a stand alone EM and bump the timing up on a stock motor, you'd gain a bunch of power but you'd also require high grade gas. |
Maybe. Could be. Filled up with Exxon 93 a couple days ago though and havent noticed any pinging or the sound Im thinking is pinging. Im thinking 87 isnt the most ideal fuel octane I should use. Yes it runs good and I get good fuel economy on 87 but the pinging worries me as far as potentially doing long term engine damage. Or maybe I have carbon deposits? But how much carbon buildup can there be after 20k miles and using quality gas?
| Pinging noise coming from the front right | hachi-roku_fan | DIY / Maintenance / Service | 3 | 01-24-2011 04:41 PM |
| Knocking / Pinging | TDaniel | DIY / Maintenance / Service | 11 | 04-08-2010 06:12 PM |
| Pinging belt when wet or cold | steveh74 | Europe (continental) | 0 | 08-22-2009 05:50 AM |
