Old 07-16-2011, 11:20 PM   #1
tbendtom
Drives: 2010 yaris
I don't know what happened??
I have a 2010 yaris; today I left the ignition key on and the battery almost drained. There was still enough left that the presets on the radio and the clock was still correct. I used my boat bat. to jump start the car...Now I find that my ipod will not come on in the aux position (it did in the aux position before I let the battery go down). My car has a aux pig-tail in the glove box that plugs in to the ipod. Cds still work, I can plug a music player in to the aux jack by the break lever and it works through the aux. I seems that if the radio is on I can't get the ipod to work...But, when I disconnect the ipod and reconnect it, it will play until I switch back to the radio, then attempt to reconnect to the ipod it will not work, the aux button brings no results; nothing on the display either...What am I doing wrong?
tbendtom is offline   Reply With Quote
Old 07-18-2011, 08:00 AM   #2
bronsin
bronsin's Avatar
Have you checked the fuses?
Old 07-18-2011, 10:17 AM   #3
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
bring it into the dealer. it should be under warranty.
Old 07-19-2011, 11:12 AM   #4
tbendtom
Drives: 2010 yaris
MY best guess is that when the battery drained down to its lowest point it messed up the programing in the radio. I disconnected the battery (after recharging) for 10 minutes; reconnected the battery and all worked as normal. Thanks for your input...73s... tom
Tom Tom to provide embedded PND for Yaris mehrit In Car Entertainment + Electronics (audio / video / alarm) 23 07-05-2009 03:09 PM
