Old 11-18-2009, 11:58 PM   #1
detroiter
detroiter's Avatar
anyone else getting water in/on their AFE intake?
Drove through the rain for the first time tonight since installing the AFE intake. Decided to check on it when I got home and to my surprise, there was a decent amount of water on the bottom of the heat shield and when feeling the filter, could definately tell it was getting misted or actual rain on it. It looks like the water is coming through the crease between the bumper and the hood, or the corner of the hood and headlight.
I took the filter off to check inside of it and it seemed dry as a bone in it and didn't see any trace of water or condensation inside the intake pipe, so I guess I'm alright. Just wondering if anyone else has/is experiencing this issue? And if so, what have you done to correct it?
Old 11-19-2009, 12:06 AM   #2
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
If water is getting in from the gap between the hood then you should pick up the MI hood seal kit. http://www.yarisworld.com/forums/sho...ight=hood+seal There's enough material to do the gaps between the lights and the bumper.
Old 11-19-2009, 01:05 AM   #3
YarisSedan
Drives: 08 Yaris Sedan
No but i did notice the heat shield where its bolted to the battery is broken. I think too much engine movement and constant tugging on the shield.
Old 11-19-2009, 01:07 AM   #4
H3LlIoN
Drives: '09 Yarrrr hatch
Not really necessary. Engine bay designed to get soaked during rain. Even with "hood seal kit" engine bay still get wet. Just avoid standing water. Hydrolock is #1 killer of 1NZ.
H3LlIoN is offline   Reply With Quote
Old 11-19-2009, 03:22 AM   #5
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Sorry , but with the hood seal and where the heat sheild is fitted
no water gets into my AFE , and there are quite a lot of people using them
now , as well that will back this up
Old 11-19-2009, 03:26 AM   #6
H3LlIoN
I'm not saying it won't prevent water from dripping down on the top of the afe, i'm just saying it's not necessary.
Toyota
Moving Forward
...even when you don't want it to.
Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
Old 11-19-2009, 07:44 PM   #7
detroiter
detroiter's Avatar
I'd imagine I'd have to be driving in the Great Lakes to actually submerge or put standing water all the way up to the afe intake lol. I guess if I didn't want to go the hood seal route, where can I purchase one of those hydrolock cover/sleeves to throw over the filter? I thought they are only like 10 bucks or so but are very waterproof, yet they allow the filter to breathe just fine.
Old 11-19-2009, 07:49 PM   #8
supmet
Drives: 2007 4 Door Yaris
really? I haven't heard of one person on the forum have their car die from hydrolock, let alone the engine being damaged.
Old 11-20-2009, 12:04 AM   #9
H3LlIoN
Roomate is a toyota tech...that's what he says kills all the ones that have to be replaced across the board.
As to the hydrolock sleeves, tyvek is the same thing, although not as pretty as what you might find at an autoparts store.
Toyota
Moving Forward
Old 11-20-2009, 12:17 AM   #10
get 'r done
Old 11-20-2009, 01:06 AM   #11
supmet
I was searching on scionlife since I couldn't find anything about hydrolock killing any yaris's's's engines. I found an interesting post, and maybe Tamago can help explain why so many of your toyota tech's engines that get replaced are "due to hydrolock."
http://scionlife.com/forums/showthread.php?t=79099
So, just because a toyota tech says hydrolock to get out of a warranty, doesn't mean it is actually hydrolock.
I still think that out of the thousands of yaris owners posting here and thousands more 1NZ owners on scionlife we'd hear about more hydrolock if it were such a huge issue. 99% of posts I've searched are just people telling other people their car will hydrolock if they install an aftermarket filter.
Old 11-20-2009, 03:32 AM   #12
H3LlIoN
Wow, I can't believe he folded that easy.
Anyway, "My Toyota Tech" had three come through the shop that were legitimately hydro-locked. None of them were modded in any way, and were basically cases of ignorant people driving through deep standing water and flooding the things. When he looked it up in the database, it was listed as #1 reason for whole engine replacement on the 1NZ. Whether or not the other cases were legitimate, we obviously can't confirm, but that's the case at our particular local. Then again, we also have at least one serious flood a year, so we tend to be a bit more susceptible than some other places, which might explain why it's not so prolific.
Toyota
Moving Forward
Old 11-20-2009, 03:32 AM   #13
H3LlIoN
get 'r done
as long as I don't have to hear it. Dumb f#%ki&g rednecks...
Toyota
Moving Forward
Old 02-24-2010, 10:26 AM   #14
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
short answer? i didn't.
Originally Posted by xnamerxx
you nailed it sir.
Old 02-25-2010, 05:01 AM   #15
yarisitis
yarisitis's Avatar
Drives: 2008 Yaris LB
You'll be fine, I've driven through pounding rain for 5 hours straight and had no problems at all.
yarisitis is offline   Reply With Quote
Old 02-25-2010, 03:26 PM   #16
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
If its nerve racking, i suggest Ingen Hydra Shield covers. About $10-$15 shipped to any state....
I have it on my intake, and my intake sits right where the foglight cover is, lower than you guys...gets wet during any amount of rain, but the shield helps it from being wet.
Old 08-12-2011, 12:50 PM   #17
henrystyle
Drives: 2010 5 door yaris
Anyone have any pics of there hood seal kit install?
henrystyle is offline   Reply With Quote
Old 08-14-2011, 01:43 AM   #18
detroiter
detroiter's Avatar
I'll try and take some for you tomorrow....necrothread ressurection by the way lol
AEM cold air intake vs Afe intake... djgab101 Performance Modifications 69 04-28-2013 03:03 PM
Garm's AFE intake vs. TRD high flow air filter???? computerlove87 Performance Modifications 28 07-22-2009 06:05 PM
AFE cai intake....pros/cons severous01 Performance Modifications 21 06-30-2009 03:55 AM
AFE Intake on a Sedan??? CASTREX Performance Modifications 7 12-12-2008 01:27 PM
