Old 09-11-2011, 05:42 PM   #1
Twistoffate0817
My Little Blue Egg :)
Twistoffate0817's Avatar
Drives: '09 3 door Yaris
Need Advice.
Hello all,
I am now commuting to school three days a week and need opinions on which is better for MPG sake. I drive 50 mph all the way there. I have googled whether or not it was better to drive with the windows down a bit, or the air circulating from the outside with the window up and cannot find an answer that makes sense. My question is...is it better to drive with the window down a bit at 50 mph, or window up with the air circulating in from the outside? Which one will give me the best MPG? Does turning the fan on setting 1, 2, 3, 4 effect my MPG? Thanks!
Twistoffate0817 is offline   Reply With Quote
Old 09-11-2011, 06:18 PM   #2
Lil Abner
Drives: 2009 3dr LB Manual
In my experience, running the air doesn't do anything for economy. And the fan speed doesn't control how much the AC compressor runs. It runs the same regardless of the fan speed.
Old 09-11-2011, 08:52 PM   #3
sickpuppy1
Drives: 2010 Yaris Sedan
If your talking about just bringing in outside air, running the blower wont affect fuel economy at all. running with the window
Old 09-12-2011, 10:13 AM   #4
SpaceShot
SpaceShot's Avatar
Drives: 2008 Yaris 5 speed HB
Either having the windows (partially) down or using the AC will take 1-3 Mpg off your trip average. Going with the windows up and the interior fan turned all the way up doesn't seem to have a measurable affect on trip Mpg.
SpaceShot is offline   Reply With Quote
Old 09-12-2011, 06:11 PM   #5
Kal-El
Kal-El's Avatar
Just be comfortable. If you're very warm or hot, put the AC on. The Yaris's AC is very efficient, unlike the old days when AC really drained power.
I never noticed more than 1 mpg difference. There's other factors that effect MPG more, like simply stop signs and red lights - they waste way more gas. Or even which way the wind is blowing which you can't control.
The difference in AC on vs windows down is extremely negligible.
Old 09-13-2011, 01:07 PM   #6
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
windows up for me at speeds over 35mph
now sometimes if its very nice out, i'll drive windows down 60+...
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 09-13-2011, 04:25 PM   #7
Twistoffate0817
I won't use the AC unless im doing highway because the AC makes my Yaris very underpowered and I have to push the pedal down hard for it to accelerate from a stop. I guess I will try using the air from the outside instead of having the window down a bit. :P
Old 09-26-2011, 04:36 AM   #8
nessan
Drives: Toyota Etios
if you are going to open windows as alternative, then I would advice you to keep ac on windows greatly disturbs aerodynamics resulting in reduction in average,
nessan is offline   Reply With Quote
Old 09-27-2011, 01:13 AM   #9
daf62757
Nothing beats a Toyota!
daf62757's Avatar
Drives: 2013 Yaris 5 dr liftback
You might want to also evaluate the terrain conditions. Driving 50 in hilly areas might actually use more gas than driving a little faster. You coast farther if you are going faster and you can go farther up a hill if you are going faster. I have found it to be a real art to squeeze out as much mileage as possible but if you drive the same route on a regular basis, you should be able to master the best speed even with the AC on. I would never put personal comfort over mileage in a Yaris. The difference is just not that great.
Big Dave
Indianapolis, IN
Synthetic Oil....its in my car.....for at least 10,000 miles!
daf62757 is offline   Reply With Quote
Old 09-27-2011, 03:41 AM   #10
mr9865
$10.25/hr frying chicken
mr9865's Avatar
Drives: 2012 Yaris L
In my ECHO driving 50 mph A/C off got me 54mpg for my hwy trip, doing the same trip at 75 I got 43mpg. Driving slow does help!
mr9865 is offline   Reply With Quote
Old 09-27-2011, 04:20 AM   #11
only way to be sure:
1) drive 1 tank with windows down exclusively
2) drive 1 tank with windows up and AC on exclusively
3) drive one tank with windows down at normal speeds and AC on at highway speeds
Keep a log of your fuel consumption under all three scenarios and see which one makes the most sense in terms of economy and comfort :)
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 02:15 AM
Need advice on head unit settings chewychewbacca In Car Entertainment + Electronics (audio / video / alarm) 18 03-18-2011 07:54 AM
Ordered some wheels, need advice on tires 47_MasoN_47 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 04-21-2010 05:56 PM
Yaris 06 T Spirit advice needed ! nocturne_sa General Yaris / Vitz Discussion 1 01-03-2010 06:24 AM
Good advice for new car owners... YarisSedan General Yaris / Vitz Discussion 10 04-15-2009 04:43 PM
