Old 01-31-2007, 11:36 PM   #1
manborn
are u still 34/39?
manborn's Avatar
Drives: flint mica yaris s sedan
longer turn over on start w/ cold weather
is this normal? i believe this started when temperatures were around 30 F and below
also i accidentally drained my tank once back in december w/c im not sure if that had any adverse effects causing issue.
manborn is offline   Reply With Quote
Old 02-01-2007, 05:38 AM   #2
spkrman
Drives: 1
huh?
Old 02-01-2007, 07:35 AM   #3
clayky
Drives: '07 Yaris S Sedan
I've noticed the same thing, but she runs fine after that.
clayky is offline   Reply With Quote
Old 02-01-2007, 08:57 AM   #4
manborn
are u still 34/39?
manborn's Avatar
Thumbs up
mine too.
thanks guys. i heard of this with other cars generally but i thought we were immune. does synthetic oil help and higher end battery?
i did use a red optima battery in my previous car and i never had this issue.
had my 1st oil change already also but i see there's no bearing in this topic.
Old 02-01-2007, 10:07 AM   #5
||)) (o) ||\||
- Donnie Demonic -
||)) (o) ||\||'s Avatar
Drives: '07 Yaris Sedan Sport
I noticed the same with my car... :E D I T: TAKES A LITTLE LONGER TO TURN OVER IN THE cold weather, but once shes running shes fine.
||)) (o) ||\|| is offline   Reply With Quote
Old 02-01-2007, 01:01 PM   #6
Go4th
Go4th's Avatar
Drives: Yaris S Sedan color Flint Mica
same here
Originally Posted by ||)) (o) ||\|| View Post
I noticed the same with my car... needs a few extra turns in this cold weather, but once shes running shes fine.
X 2
Go4th is offline   Reply With Quote
Old 02-01-2007, 02:40 PM   #7
punch
punch's Avatar
umm the yaris only requires one turn, and then let go the car does the rest (cranks)for you.
punch is offline   Reply With Quote
Old 02-01-2007, 02:55 PM   #8
ChinoCharles
Drives: LB
Sedan only. Err... automatics only?
All I know is mine doesn't do it.
EDIT: Liftbacks do it too... whoops.
Old 02-01-2007, 07:44 AM   #9
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
It is harder to start any car in cold weather.
Old 02-01-2007, 08:33 AM   #10
d2dailly
Roar?
Drives: 07 White LB Yaris
Send a message via AIM to d2dailly
oil is thicker in colder weather and battery doesnt have as many cranking amps in cold weather below freezing
d2dailly is offline   Reply With Quote
Old 02-01-2007, 01:34 PM   #11
ChinoCharles
Drives: LB
Yep, me too. Nothing to worry about.
Old 02-01-2007, 11:39 PM   #12
mikeukrainetz
mikeukrainetz's Avatar
Drives: 2006 Toyota Yaris
whats the cca on the stock batt? bet a decent battery would solve the struggling to start issue, mine does that all the time.
mikeukrainetz is offline   Reply With Quote
Old 02-02-2007, 09:11 PM   #13
YANGSTER
YANGSTER's Avatar
Drives: SILVER YARIS 2007 5DR
NORMAL....same experience here.
YANGSTER is offline   Reply With Quote
Old 02-02-2007, 09:54 PM   #14
spkrman
Drives: 1
yea normal
Old 02-04-2007, 03:09 PM   #15
eco
eco's Avatar
Drives: 2007 Black Yaris sedan
Same here,long starts at about freezing and below.I love that "auto start",how did you not know this CC.
eco is offline   Reply With Quote
Old 02-04-2007, 03:14 PM   #16
ECHOKnight2000
Small Car Lover
ECHOKnight2000's Avatar
Drives: A Super Car
Today, its been really really cold where I live like below 0 without windchill...anyway my car was outside overnight and I decided to bring it in the garage, man did it have a long turn over. Then when it was on the engine sounded like a diesel truck! It was awesome! I know its because its been sitting there and its really cold so its going to run/idle rough at first until it warms up. According to my scanguage the coolent temp was below 0! Although it warmed up fairly fast. I hate the cold and winter...That's my warm up story
You may look good on the beach but in reality you're a pompus, egotistical jerk. "I was never on the beach with you..."and you never will.
ECHOKnight2000 is offline   Reply With Quote
Old 02-04-2007, 04:26 PM   #17
hystria
hystria's Avatar
Drives: 2007 Orange Yaris Hb 3Drs
we got below O F too, the car doesn't crank more than during summer time... and the idle is normal. The only noticeable thing is the clutch pedal which is kind of stiffer. I use synthetic oil if that changes anything...
hystria is offline   Reply With Quote
Old 02-05-2007, 12:34 AM   #18
eco
eco's Avatar
The synthetic oil does help alittle.So does a better oil filter,I just switched to TRD's version.
Reluctant upshift to 3rd while cold (auto trans) pauljk General Yaris / Vitz Discussion 40 01-22-2011 07:04 AM
