Old 07-11-2015, 07:38 AM   #1
bronsin
bronsin's Avatar
Low Pressure In One Tire!
Even though I have tire pressure alert I check my tire pressures two or three times a month.
I find the pressure drops in the fall when temperatures drop also and air needs to be added.
But for the most part, three of my tires maintain 35 psi almost always while one tire will only hold 30 psi.
If I bring the pressure up to 35 by the next check its down to 30 again.
Yet it never falls below 30!
In 40 years of driving I never saw that. IF a tire has a leak it keeps on leaking until pressure is zero.
But not this one!
Old 07-11-2015, 12:25 PM   #2
nookandcrannycar
I'm having this issue ^^^^^ with the (now) left front tire on my '14. The dealer put 'lifetime nitrogen fill for the tires' on the PAC sticker that was taken off the price before the price I found on the internet. I wonder if this slow leak = re nitrogen, re the crappy and thin tires Toyota put on the car, or re some small road hazard. The TPMS eventually kicks in and trips the light, but IMO that should happen sooner than it does.
Old 07-11-2015, 10:56 PM   #3
IllusionX
Drives: 07 Yaris Sedan Aero
Sometimes a slow leak needs certain pressure to leak, until then it will stop leaking..
Old 07-12-2015, 01:25 AM   #4
bairjo
You took the words right off my keyboard...
Old 07-12-2015, 07:35 AM   #5
bronsin
bronsin's Avatar
Time for fix a flat!
Is FAF approved for tire pressure sending units?
Old 07-12-2015, 10:45 AM   #6
Rigaud
Drives: 2009 Yaris
This!!!
Old 07-12-2015, 11:31 AM   #7
nookandcrannycar
I don't know about that, but FAF and like competitors invalidate the tire warranty for at least one tire retailer.....Firestone.
Old 07-12-2015, 01:05 PM   #8
IllusionX
You can't use FAF on wheels fitted with TPMS, because it will gunk the sensor and render it unusable.
tire pressure walt101786 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 03-01-2011 05:20 PM
Yaris 09 1.33 tire pressure yannis-b General Yaris / Vitz Discussion 12 12-09-2009 08:12 PM
screw more psi in the tires. thebarber Fuel Economy Forum 43 05-04-2009 05:46 PM
Tire Pressure slvryaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 11-05-2006 01:37 PM
