Old 06-20-2012, 10:13 AM   #1
Qmobile
that's right I went there
Qmobile's Avatar
Drives: '08 Blazin' Blue,'10 Dark Red
DRL mod idea
I've always thought that it'd be cool if there was a way to turn the DRLs on and off via some sort switch while the car is running. For the times when you want to be in "stealth mode" or like say if your in a drive-in (yes they ARE still around) and don't want to disturb anybody. I know most new cars that I've seen have some sort of switch, any ideas?
Mods: 15" SSC rims, TRD Exhaust, TRD Sway bar, TRD oil filler, TRD rad. cap, TYC tails, Debadged, Painted engine cover, Stock spoiler, Stock mud gaurds, OBX pedals.
suggestions always welcome
Qmobile is offline   Reply With Quote
Old 06-20-2012, 10:34 AM   #2
my2sense
Drives: 2007 Red 5dr RS
This can be done easily by putting a switch on one of the DRL relay wires. I can't remember the specifics right now but I believe it's the blue wire. There's a thread on here on how to remove the DRL relay that should give you an idea of where to start. The wires are really short and tight near the relay though so it will be a pain to splice a switch to the wire.
my2sense is offline   Reply With Quote
Old 06-20-2012, 10:55 AM   #3
Correct - The large blue wire in pin 1 of the DRL connector.
Old 06-20-2012, 10:54 AM   #4
TOLMACH
Drives: soarer
just add the switch as described above
enable DRL at Yaris 2009-2011 Ot_tO DIY / Maintenance / Service 6 06-15-2012 05:13 PM
08 HB DRL Issue BruceLee Cosmetic Modifications (Exterior/Interior) 3 02-18-2012 10:59 PM
DRL to city/aux fog/LED dean_park DIY / Maintenance / Service 9 09-13-2010 10:03 AM
HID flickering problem - DRL fog - Problem solved. IllusionX Cosmetic Modifications (Exterior/Interior) 9 10-01-2009 06:37 PM
