Old 06-14-2014, 12:23 AM   #1
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Clutch Maintenance
This is something that a lot of folks forget with a manual transmission to work toward a smooth running clutch and is cheap/easy to do.
The Problem
When driven aggressively, economy cars with manual transmissions and boosted engines sometimes fall prey to clutch pedal issues during or following high-rpm shifts. For clarity sake, driven “aggressively” means cars that are launched or see high-rpm up-shifts or down-shifts. And consequential clutch problems affect many brands of cars and motorcycles too.
The general symptoms include a clutch pedal that becomes
• Hard
• Soft
• Slow to return or lazy
• Hung mid-way up or
• Stuck to the floor
These misbehaviors are commonly called clutch pedal “woes.”
The Cause
Over the years various theories have been advanced on the root cause of pedal woes. There is no broad agreement, but one fact does seem to remain constant.
Faced with pedal woes, replacing all clutch and hydraulic components with new stock parts does not prevent a quick return of the same symptoms in a car driven aggressively. And upon tear-down inspection, none of the parts shows obvious failure.
Through experimentation, I found that keeping the clutch fluid fresh and clean prevented a recurrence of pedal woes in my use. Three 1NZs and 50 passes at the land speed strip later, my clutches have behaved normally due to my keeping the clutch fluid clean, via to the protocol I recommend.
Preventative maintenance (frequent swaps of the fluid via the master cylinder reservoir) definitely works. It also explains why, if the seals are already damaged by clutch dust, no amount of clean fluid will heal them. The crucial element is prevention, never allowing the clutch dust to accumulate in the fluid. The tell of its presence is murkiness or cloudiness. So don’t allow the fluid to stay murky.
I think water entering the fluid via heat-cool cycles plays a roll in clutch pedal issues. So frequent changes of the clutch fluid ought to be part of routine maintenance for owners who don’t do aggressive launch or shifts.
The routine I personally follow costs about $20 and two hours of my time per year. That’s a small investment with a big return in reliability and driving pleasure.
The Goal
Keep the fluid in your clutch hydraulics free of accumulated clutch dust. And Keep the fluid near the nominal dry boiling point on the can (450F to 500F, depending on the brand), and keep the fluid dry, e.g. without contamination by infusion of water.
If that is accomplished by frequent changes of the reservoir content, the clutch hydraulics will never see accumulated clutch dust nor a temperature high enough to make the fluid boil, the dual origins of pedal woes. And the seals will enjoy a long service-life, if kept free of clutch dust ravages.
Murkiness is “the tell” that fluid is degrading. The darker the fluid is when agitated, the more urgent it is for it to be cleaned up before pedal woes take hold.
The Steps I take:
Step 1
Inspect the fluid in the clutch master cylinder reservoir. If it’s not clear and clean move to step (2).
Step 2
Change the fluid in the clutch master cylinder reservoir.
(a) Draw out the discolored fluid with a syringe, keeping the corrosive fluid off your paint.
(b) Wipe down the reservoir and the diaphragm on the cap, using a clean, lint-free towel.
(c) Locate the fill-line in or on the reservoir.
(d) Refill the reservoir to just below the fill-line with fresh fluid specified in your owner’s manual. Do not over-fill. If the reservoir has both minimum and maximum marks, suggest filling to the midpoint.
(e) Clean the diaphragm if dirty and properly seat it on the reservoir cap.
(f) Replace the reservoir cap snugly.
Step 3
With the engine off, pump the clutch pedal full-top to full-bottom to full-top 30 times. This action causes fluid in the clutch hydraulics to circulate, blending the new and old fluid, and revealing the color of the blend. It also helps scour residue from the actuator (slave) and displace upward into the reservoir any air trapped in the hydraulics. Alternatively, you can drive the car 5-10 miles.
Step 4
Then, re-inspect the blended fluid in the reservoir. If it is totally clear and shows zero murkiness, you are finished. If it's not, restart at (2). Continue to change the fluid as many times as needed, with the full, slow top-to-bottom-to-top pedal pumps between changes, until it remains absolutely clear and clean. Getting the fluid clean the first time is the hard part.
Step 5
Next come the easy part, keeping it clean. Re-inspect the clutch fluid each time you add gasoline or prepare for spirited driving, including the track. If it is not still clear and clean, restart at Step-2. Usually will take only two or three swaps to get the fluid pristine again.
Even badly degraded, dirty clutch fluid can be substantially cleaned up in 10-20 reservoir changes. This takes less than an hour, costs less than $10 for fluid and a syringe, and doesn’t require a service visit. I recommend this protocol for clutches on cars with engines that see any form of aggressive driving. If you follow this protocol, you very likely will avoid clutch pedal issues. And that is a very important assurance, because the car’s performance depends on a properly operating clutch.
Even though I just about direct quoted this reference to learn more it is worth your time. He is talking about the Corvette, but I found this a few years ago and have stuck to it:
http://www.rangeracceleration.com/Clutch_Care.html
sent from my m-o-b-i-l-e
Old 12-26-2014, 08:53 AM   #2
saxiaq
Drives: Yaris T3 D-4D
Just a small question. Can you help me locate the clutch reservoir on my 07 1.4D4D please. Is it the same reservoir of the brake fluid?
saxiaq is offline   Reply With Quote
Old 12-26-2014, 04:35 PM   #3
nookandcrannycar
Just to let you know, the OP posted a thread a few months ago that he is taking a break from Yarisworld and all other social media until at least the end of the year. So, you'll likely need to wait at least a week for his answer. Others have this knowledge, and may weigh in with the information if they notice this thread.
Old 12-29-2014, 10:15 AM   #4
CueBall
Ruler of the free world
Drives: 09 Yaris 2D HB
I was under the impression the brake and clutch share a resorvior?
I am also under the impression that just pumping the peddle will not actually 'circulate' fluid.. it needs to be bled, just like the brakes. Can someone clarify this?
CueBall is offline   Reply With Quote
Old 01-03-2015, 09:57 AM   #5
colj00
DIYer
Drives: yaris 1.5 MT
got a question, how would clutch dust get into the fluid?
the yaris uses an external slave cylinder.
colj00 is offline   Reply With Quote
Old 03-28-2016, 06:19 PM   #6
littlecars
Drives: 2007 Yaris 2 door hatch manual
Yes, clutch fluid must be bled, just like brake fluid or the slave cylinder will not benefit from the clean brake fluid that replaces what was sucked out of the master cylinder reservoir. Clutch / brake fluid is hydroscopic, meaning water loving. The fluid contains moisture that enters your brake or clutch system from the atmosphere. After a few years the fluid is water saturated and must be changed or your master and slave cylinders and fluid lines will corrode! Suck out the old (dark colored) fluid. Replace with new (clear or honey colored) brake fluid, and bleed that through to the slave cylinder(s) until it comes out clear. Keep topping off the reservoir as you bleed to avoid getting air in the brake or clutch lines!
littlecars is offline   Reply With Quote
Old 04-04-2016, 01:50 PM   #7
mik23
Drives: yaris 2005
Gents
Where is this located can someone post a photo for yaris.
mik23 is offline   Reply With Quote
Old 04-04-2016, 02:06 PM   #8
tmontague
tmontague's Avatar
brake fluid reservoir and clutch fluid reservoir are shared.
I tend to start with the brakes (furthest form reservoir and work to the closest) and then finished with a bleed o the clutch.
Old 07-23-2016, 01:13 PM   #9
dogsridewith
Drives: 2007 2-door hatchback
clutch fluid reservoir...The Mind of Toyota
not saying it is a bad idea...I kind of like it. But, it IS NOT NORMAL for the clutch fluid reservoir to BE the brake fluid reservoir. So, while you're telling us in Specifications that brake and clutch fluid are the same, couldn't you mention somewhere in that fat owners manual where to check and add clutch fluid?
Old 07-23-2016, 01:23 PM   #10
Kalispel
Kalispel's Avatar
Drives: '15 Yaris SE 5MT
Is this really necessary if the car is driven normally as a daily driver? My previous manual 5-spd 2000 Honda Accord Sedan had almost 200K miles on it when I sold it, and had the original OEM clutch still working pretty much like it had since I bought it new 15 years ago. The clutch was never bled, though I did have the transmission fluid/oil drained/changed once @ 150K (more as a preventative than because anything actually 'felt wrong').
Kalispel is offline   Reply With Quote
Old 07-23-2016, 01:46 PM   #11
dogsridewith
Tercel clutch fluid
My 89 Tercel 2dr hatch took longer to die of rust than I thought it would, and it didn't get fancy maintenance at the end. Clutch fluid reservoir got too low, clutch dragged at full pedal down, and all I did was add fluid. All back to normal in a few days. Never bled anything. But not all systems will respond like this.
Old 03-03-2017, 10:44 AM   #12
mik23
Drives: yaris 2005
How to bleed the clutch fluid where is the plug located.
Old 03-03-2017, 11:42 AM   #13
tmontague
tmontague's Avatar
You use the bleed nipple located on the slave cylinder which sits on the front of the transmission. You fill at the master brake cylinder as they are shared reservoirs.
HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. trini_per4mance DIY / Maintenance / Service 42 03-27-2017 04:59 AM
need help on my 2008 yaris compress clutch susucosp DIY / Maintenance / Service 0 05-15-2014 04:48 PM
Clutch question. Black_griffin6 Performance Modifications 6 04-04-2013 05:30 PM
Help Me Find The Right Clutch RacerFreakXXX Performance Modifications 18 10-20-2010 06:20 PM
Having clutch issues ? hystria DIY / Maintenance / Service 10 08-22-2007 12:34 PM
