Old 02-02-2012, 07:48 PM   #1
vhicke
Drives: yaris
Constant 12v power locks
I am going to be installing power locks on the two front doors of my 2008 sedan. It is a universal kit with remote unlock and just wondering where I should get the 12v from. I would like to put the module on drivers side panel. Thanks
vhicke is offline   Reply With Quote
Old 02-02-2012, 07:51 PM   #2
Use the location on the under dash fuse panel that I show in my remote start DIY. Power locks require a significant amount of current (15+ A), so using that location works well, as it has the ability to feed up to 60A.
http://www.yarisworld.com/forums/showthread.php?t=24860
Old 02-02-2012, 08:14 PM   #3
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
or get a reeeealllllyyyyy long extension cord to the house
Old 02-02-2012, 08:29 PM   #4
vhicke
Drives: yaris
Can i use this female connector for my needs and do i connect to the top pin or the bottom or does it not matter as they both have 12v coming from them.thanks
Old 02-02-2012, 09:01 PM   #5
fnkngrv
fnkngrv's Avatar
You can use one like that however be sure that you pick up the one with a sheath. What gauge wire did your kit come with or what gauge do you plan on using?
Old 02-02-2012, 09:07 PM   #6
vhicke
Drives: yaris
This is the kit i got on ebay.....Does not have any info just a shitty diagram of what goes where.....
http://www.ebay.ca/itm/190631927472?...84.m1497.l2649
Old 02-02-2012, 09:47 PM   #7
vhicke
Drives: yaris
I just compared the wire to another i have and it looks like it is 16 gauge. So do i connect this to top pin or the bottom on the fuse panel spot that ctscott said to put it.
Old 02-02-2012, 09:54 PM   #8
The top one. The bottom isn't connected to anything.
Old 02-02-2012, 09:58 PM   #9
vhicke
Drives: yaris
Cool thanks for the help guys....
Question about Power Locks absolution8 General Yaris / Vitz Discussion 3 05-30-2011 07:20 AM
Power windows and locks on a 2009 3dr. chilly79 DIY / Maintenance / Service 8 12-15-2010 01:55 PM
Questions and advice required about power upgrading(windows & locks) W.A.S.P DIY / Maintenance / Service 10 07-22-2009 03:59 AM
Where can i get constant power from? Syroyizhka General Yaris / Vitz Discussion 7 04-30-2009 12:08 AM
