Old 03-12-2012, 08:24 PM   #1
12 yaris
Drives: '12 Yaris LE Lagoon Blue Mica
Tire Pressure Sensors
Tire pressure sensors are not covered. I had a blow out today,
the blow caused damage to the sensor found out it wasn't
covered under warranty. After considering taking a tire iron
over the service manager's head, I decided it wasn't worth it.
Also upgraded garbage Good Year tires,since there wern't any available
from local Good Year tire shop that Good Year owns and operates.
Just a heads up guys and gals.
12 yaris is offline   Reply With Quote
Old 03-12-2012, 08:33 PM   #2
Billiam
Drives: '10 White Yaris 4D LB
Why would they warranty something that was damaged?
If you want to enjoy your car, stay off of the internet.
Old 03-12-2012, 08:39 PM   #3
12 yaris
They(York Auto Group)said it was normal wear and tear.
Today was the last time they will ever see my car.
I just think it's B.S.,I just paid 16K for the car(they made money).
Pretty piss poor customer satisfaction.
Old 03-12-2012, 08:51 PM   #4
Billiam
No...I'm asking you...why would they warranty something that was damaged? It wasn't defective, it was damaged. If you dented the fender would they warranty that too? See what I'm saying?
Old 03-12-2012, 08:55 PM   #5
12 yaris
I guess maybe I'm from the old school.
Would you lose a customer over a hundred dollar sensor?
Old 03-16-2012, 03:12 PM   #6
12 yaris
Purchased a sensor from our sponser Tire Rack and installed
yesterday, progrmmed it,however I could not communicate
with the remaining three(neither could the Toyota dealership).
They wanted too charge 140.00 to remove the tires and try to determine
the problem.
I said no way.
Contacted Toyota Corp. and explained what happened,what they
told me,what I did yesterday,and what the dealership did today.
I had asked Toyota Corp. if they had any problems with the '12 sensors,
they said they had not yet. I'm sure Toyota Corp will correct the problem.
Old 03-16-2012, 03:23 PM   #7
Scubaru Steve
Awesome!
Drives: 12 Yaris/07 yaris
the sensors have to be "relearned", your car wont recognize it otherwise. take your car to a tire shop to get the sensors learned and your problem should go away.
Old 03-16-2012, 03:40 PM   #8
12 yaris
That is what the dealership tried to do today.
Old 03-18-2012, 07:38 AM   #9
AndreS123
Drives: 2012 Yaris L, 2017 Yaris L
Has anyone tried to do a TPS system override/disable on the '12 yet?
I'm already at 3500 miles, when the first set of tires is done, they will be coming off in favor of a common, more easily obtained, and less expensive size.
AndreS123 is offline   Reply With Quote
Old 03-18-2012, 09:11 AM   #10
The bypass won't be as easy on a 2012, since the TPWS is now a bit smarter than it was on the 2nd gen. With the 2nd gen the TPWS was a standalone system that drove an LED on the cluster. With the 3rd gen it communicates to the Body ECU via LIN bus and then the Body ECU communicates with the cluster via CAN bus and the cluster drives the LED based on the CAN bus messaging.
Old 03-18-2012, 01:34 PM   #11
skuzzlebutt5
Drives: '12 Yaris SE Classic Silver AT
@ CTScott - Can you put that in laymen terms?
skuzzlebutt5 is offline   Reply With Quote
Old 03-18-2012, 02:01 PM   #12
Yes - There is no easy way to bypass the TPMS, other than taking the cluster apart and sticking a piece of black tape over the LED.
Old 03-18-2012, 02:31 PM   #13
^ my solution for the airbag light
Old 03-18-2012, 06:14 PM   #14
auxmike
auxmike's Avatar
Somewhere on here is a DIY on how to cut a lead in the TPMS black box and make the light go away for good. 2nd Gen only, sorry!
Curious; If I throw my 4 original TMPS steelies with the original tires on them into the back of my car will that make the light go out when I go for inspection? I'd like to keep my newer NON tpms alloys on since the tires are newer with better treads.
Tire pressure sensors Yaris2go Great Lakes 4 03-19-2012 09:04 AM
4 OEM YARIS TIRE PRESSURE SENSORS FOR SALE mehullica Items for Sale by private party 13 04-14-2011 12:06 AM
NITROGEN GAS TIRE FILL: WORTH IT? EjDaPogi Middle East 15 03-20-2011 03:06 AM
The Tire inflation debate... Tankota General Yaris / Vitz Discussion 20 06-01-2006 08:09 PM
