Old 03-03-2012, 12:15 AM   #1
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
cruise control question
ever since i installed my cruise control, i've been using it constantly, even on local roads i would set it to the speed limit and let the car drive itself. i find it really useful. I want to know if it will damage the ecu or cruise control if I always use it?
is there anyway i can get it to work at low speed?
can i install adaptive cruise control on the yaris?
caineroad is offline   Reply With Quote
Old 03-03-2012, 12:39 AM   #2
You won't hurt anything (other than perhaps gas mileage a bit) by using it frequently. With a drive by wire car, like ours, there really isn't any difference between the gas pedal or the ECM itself being the device that determines how much to drive the throttle motor.
Low speed operation really isn't an option, since the threshold is hard coded into the ECM.
Old 03-03-2012, 03:26 AM   #3
Yaristeve
Drives: 3-door hatch
I sure hope not!!! I commute 35miles one way and I use it everyday, both ways. No problems so far!!!
DIY Cruise Control FAQ (2006-2010 Yaris) CTScott DIY / Maintenance / Service 468 11-19-2024 04:45 PM
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 04:43 AM
Rostra 250-1731 cruise control kit for Yaris PeetYaris In Car Entertainment + Electronics (audio / video / alarm) 5 06-26-2011 07:48 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 04:55 PM
