![]() Drives: Yaris ts 1.5 Join Date: Sep 2009
yaris ts 1.5 turbo
Hello my friends!!
I have a yaris ts 1.5 2004. I am looking forward to turbocharge it! My 1nz fe has the following and only changed components: 1) CP pistons 9:1 75mm (stock bore) 2) Crower rods and better rod bearings 3) stiffer valves and valve springs 4) toga engine bearings soon i will get a walbro 255L/h fuel pump and larger injectors. For ECU I will install a standalone Link g4 storm. The turbo I chose is the Garret2554R. When I put the turbo I will also put denso iridium spark plugs. My goal is to achieve maximum 230hp at the crank reliably. As for the injectors I will get 370cc or 440cc . which of the two would you choose? Last edited by Paris vvt-i; 10-15-2010 at 03:15 PM. |
Anyone?????
larger injectors for that power, you'll need them.
probably need a return line too. what turbo are you going to use?
Thank you. I will use the GARRET 2554R!
230 bhp is about 210 whp, you should be fine with the GT2554R. Good luck with the project, that will be a very fast car.
+1 with what garm said, go with the 440cc injectors just in case you're planning to upgrade your turbo in the future.
you can also check out this 1nz-fe here, the car made 200 whp using the GT2554R on automatic transmission with a meth kit and standalone ecu. by the way, hi garm long time no see! :)
454 whp, 1.7 bar boost, pump gas, water/meth. 501 whp, 2.2 bar boost, pump gas + avgas, no water/meth. www.viosturbo.com - World's first 500 WHP 1NZ-FE |
Yeah, nice idea. I've been contemplating on boosting my Yaris for a Loooooong time, I would like to follow you on this one, but funds wont allow it just yet.
Thank you all of you! but this 1nzfe made 200whp with a completely stock motor????? I thought Garm had the max safe hp on a stock 1nzfe (182whp)??
No one knows exactly how much power you can push vs. how long the motor will last.
Well. someone figure it out the hard way. Please. LOL
^ I mean someone go beat up on a stock motor until it gives up, so we can all learn.
I am also thinking of changing the transmission to one of a 2nz fe which has longer gear ratios
#13 | |
though this guy here has been pushing the stock 1nzfe motor with his turbo kit for more than 3 years, and is an often guest at the local track circuit.
240 whp?? on a stock motor????
. by the way what exactly is that water/methanol kit?
do you think that stock 2nzfe transmission will withstand 230hp?
We have almost done with the exhaust and intercooler! photos soon
![]() Drives: YRS 5dr MT Join Date: Mar 2011
Looking forward to your next post...
don't worry about the transmission, it'll hold the power.
| Bolt on turbo kit for our yaris! | aucorium | Forced Induction Forum | 57 | 02-02-2010 08:50 PM |
| TURBO KIT for Yaris 1.3 or 1.5 | Giupo | Items for Sale by private party | 27 | 01-22-2010 12:01 PM |
| Toyota Yaris I 1.5 Polished K&N Typhoon | FAB | Items for Sale by private party | 2 | 10-30-2009 04:57 AM |
