![]() ![]() Drives: 2009 3 door Liftback Join Date: Jul 2009
Front brake clunk after reversing
Hey all,
I've noticed that when I reverse and then apply the brakes, there's a clunk sound coming from the front end (brakes?). Is this normal or is something getting loose over time? Thanks for any ideas, Jon |
Not quite a noob
Is it a clunk or a grating noise? If it's the latter, that's a condition of brakes on an automatic. because braking is almost always done going in a forward motion, the brake disk is kind of "smeared" in one direction by the frequent braking while it is rotating counter clockwise (or clockwise, on the passenger side). When you brake going backwards the pads are now working against a grain, like cheese over a cheese grater. Hence the noise.
No, it's just a cluck. Could it be the calipers?
Not quite a noob
If one of the pistons is jammed, perhaps. Hard to diagnose unless you're familiar with brakes.
Try a test. Reverse, and while you still have momentum, brake. Then, try reverse, then after you come to a stop (with no backward momentum), brake. |
![]() ![]() Drives: 2007 Yaris Join Date: Jan 2012
nothing to worry about it's just the pads hitting the caliper when going backwards
your pads are supposed to have U shaped shim on top if that shim is crushed or missing it would cause the noise |
Thanks for all the input. After searching around the net, as well, it seems it is probably just the pads shifting. I'll just keep an ear out for if the clunk gets louder, etc.
Thanks again, Jon |
![]() ![]() Drives: yaris sedan Join Date: Oct 2008
just put grey gasket silicone in the pad`s ears and voilaaa!! excuse for my english :-)
see my image |
| DIY (sorta) - RunStop Rear disc brake conversion | eTiMaGo | DIY / Maintenance / Service | 17 | 07-02-2019 09:24 AM |
| lowering spring specs for Yaris | botchilah | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 03-22-2017 09:47 AM |
| DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside | YarisSedan | DIY / Maintenance / Service | 73 | 03-11-2017 07:05 PM |
| Which front bar do you prefer? Strut or Sway? | TitaniumBarbell | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 17 | 10-16-2009 12:52 PM |
| BIG(GER)TM BRAKE KIT | Vanderkitten | Performance Modifications | 23 | 01-04-2009 08:16 PM |
