![]() Drives: Toyota Hatchback Yaris 2010 Join Date: Aug 2013
Installing AMP 2010 yaris HB
I was planning to get this bass package from crutchfield
http://www.crutchfield.com/p_236MB21....html?tp=61893 i just need suggestions on where to put the amp. should i just screw it on the subwoofer box? thank you
![]() ![]() ![]() ![]() Drives: soarer Join Date: Feb 2011
Screwing it to the box would definitely be the easiest option
There is also plenty of space under the passenger seat. |
There's a lot of room under the passenger seat. I installed my 21" long 4 channel amp under there. If you install it on the box, you'll need to run some pretty large gauge wire all the way back from the battery. Under the set would be a much shorter run, and you could use smaller gauge wire.
Give a man a fish, and he'll eat for a day. Sell a man a fish, and you'll both eat for a day.
ok thank you so much for the replies! its going to be my first time doing this so crossing fingers lol
is it hard to remove the passenger seat? after i remove it do i just screw the amp on the floor or do i need to do something else ? |
4 E10 torx head bolts. Slide seat forward to reveal 2 in the rear of sliders, slide seat back to reveal 2 in the front of sliders.
#6 | |
you're gonna need some basic tools like jigsaw, drill, some mdf, etc. |
I dont have that much tools on where i am now , i was just thinking on mounting the amp on a plywood and hiding it securely under where the spare tire is :/
Thank you so much ill post update once i have everything :)
go with 4 gauge kit
Roadrunner Jr.
Keep the ground as short as possible. Remember to fuse the amp within 18" of the battery as well.
Also, before you turn on the amplifier turn the gain all the way down...just in case you have any Voltage spikes when turning it on. Take a look at the options for the amplifier's crossover section to make sure you've dialed everything as well as possible before you turn it on.
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
#12 | |
^ This is how TOLMACH did.. small pod, covered by the automotive carpet. blue wire is ground, positive is well protected.. crappy interconnects are for subwoofer amp - look like garbage but do the job
i then changed the seats, hence had to move the second amp to the other side front amp interconnects are on the other side (self-made) |
(i know.. could not find any hear shrink tube around (( now buy this stuff from e-bay)
#15 | |
^ Thanks
#17 | |
can someone give a link for a good amp kit on ebay or anywhere for this bass package : http://www.crutchfield.com/S-FNtFp7r....html?tp=61893 |
http://www.ebay.com/itm/23-OVERSIZE-...item4d0df2b7cc
I like that they say their gauge 4 is real gauge 4 (25 mm2) Cheaper stuff will also do the job http://www.ebay.com/itm/4-Gauge-Amp-...item19e59d8f2c |
| 2010 Yaris Stereo Install Help | FPG | In Car Entertainment + Electronics (audio / video / alarm) | 13 | 04-21-2012 10:16 PM |
| CONSUMER REPORTS : March issue : 2010 YARIS sedan | Hershey | General Yaris / Vitz Discussion | 41 | 02-18-2011 04:41 AM |
