![]() ![]() Drives: 2007 4dr sedan Join Date: Jun 2009
Wheel Stud specs
I'll be changing over from winter to summer tires and would like to clean up the stud threads with a die. Does anyone know what size die I should use?
![]() ![]() ![]() ![]() Drives: soarer Join Date: Feb 2011
studs have 12 x 1.5 mm thread
your studs are rusty? why not just clean /grease them? (to grease is usually not a good advice but needed sometimes) |
Thanks but I think the problem is not so much rust or dirt but with an over enthusiastic tire changer who was in love with his air tools' power.
I'm not sure if the threads have been stretched or not so I want to try the die before I resort to changing the studs. |
#4 | |
Good luck anyways |
Thanks. I appreciate the info.
Form>Function
You should have that guy just put up the cost for new ones.
Only Happy When it Rains
yea exactly. I would flip if someone wrecked my lugs/studs etc.
Colin Chapman disciple |
Form>Function
everytime i look to see who the most recent post belongs to in a thread and I see "why?" it always throws me off lol
indeed. one of many reasons i love to use it as a handle.
Have a look for a "thread chaser" rather than a die. They are made to clean up threads rather than cut new ones. Will work better (cheaper too).
When over-torqued it's often the lugs that get damaged. The small end of the taper gets pinched in causing it to be tight on the lug. Cheers. |
Thanks. Will do.
| The Yaris Steering Wheel | wornways | General Yaris / Vitz Discussion | 12 | 10-09-2012 01:41 PM |
| Broken Wheel stud !! | vten | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 08-26-2011 10:04 AM |
| How much would you pay for a warranty supported steering wheel extension? (3d try) | wornways | General Yaris / Vitz Discussion | 36 | 09-16-2009 10:16 AM |
| forged rims Vs. alloys | red-jdm | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 07-23-2007 08:30 PM |
