Old 05-07-2012, 06:44 PM   #1
Patocine
Drives: New Yaris Sedan
Valve lifter Problem !!!
I have a New Yaris Sedan 2007.
The stock has 16 valve lifter.
Like that;
these were removed and not installing them.
Each Valve Lifter has a number. ( 34,36,38,41,42 )
after install ,It sounds a harmonized and tac tac tac, is the valve.
As I can know the position of each Valve Lifter.
Thank you.
Patocine is offline   Reply With Quote
Old 05-07-2012, 07:00 PM   #2
The lifters are available from Toyota in 35 sizes ranging from 5.060 to 5.740 mm.
Look at the "Engine Mechanical" section of the service manual in the link below and start around page EM-13 for information on how to determine the correct lifter thickness for each valve:
http://www.microimageonline.com/foru...32-YARIS-FILES
Old 05-07-2012, 09:20 PM   #3
Patocine
Thanks 4 u Reply but.
I do not understand the manual.
I have the following Valve Lifter
Number Cant.
Lifter
32 x 1
34 x 3
36 x 1
38 x 3
39 x 1
41 x 6
42 x 1
how to install ?
Thanks.
Old 05-07-2012, 10:09 PM   #4
Viperoni
Drives: 2005 Toyota Echo
The valves are sized differently depending on the clearance in each lifter "pocket" in the cylinder head. This is how the valve lash is changed/adjusted.
You need to fit the correct sized lifter into the pocket.
The numbers on the lifters do not tell the order or sequence that they need to be installed, only the size.
You need to measure each lifter and put it into the correct pocket.
2006 Saturn Ion Redline
Old 05-07-2012, 11:21 PM   #5
Patocine
And how i know , the correct measure for each pocket ?
Thanks.
Old 05-08-2012, 06:40 AM   #6
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Maybe we could get someone who speaks Spanish to help?
Did you measure the valve clearances before removing the lifters? If not, you will have to try different combinations to get the right valve clearance:
Originally Posted by Page EM-9, step 8(d)(1)
Using a feeler gauge, measure the clearance between the valve lifter and camshaft.
Valve clearance (cold):
for intake:
0.15 to 0.25 mm (0.006 to 0.010 in.)
for exhaust:
0.25 to0.35 mm (0.010 to 0.014 in.)
That means installing the lifters and cams again and starting over.
Old 05-08-2012, 11:09 AM   #7
Patocine
Tienes razon lo mejor seria que me explicara alguien en espaņol.
It has been very helpful post.
thanks
Variable Valve Sensor Error Craig DIY / Maintenance / Service 13 06-22-2013 03:29 AM
Warrany Service Problem? 2009Yaris General Yaris / Vitz Discussion 4 03-31-2011 04:56 PM
Problem with my car rakhan01 DIY / Maintenance / Service 8 12-03-2010 05:12 AM
Launching @ 4Krpm problem .... need tips Parmas Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 12-30-2009 08:11 PM
