![]() ![]() Drives: Yaris RS 2007 Join Date: Oct 2006
Door Handle LED DIY with pics
Finally I have time to take some pics of the DIY. Since my english is very poor, I will use pics instead of speaking. Hope this will help and feel free to ask questions and add comments.
I am having a 5 Dr yaris, so I will start with the front door and you can get the LEDs from Walmart for $10 (4 of them) 1. open the front door and locate the black stuff which cover the screw and remove it ![]() 2. unscrew the screw (the screw has something to hold on to it, so no worry it will fall into the door) ![]() 3. after you unscrew it, remove the lock and the handle ![]() slide the handle toward the back of the car and remove it ![]() 4. drill a hole in the handle and put your LED in it (I used hot glue to keep the LED in place) ![]() 5. run the wire in the door and through the wire tube into the car ![]() Now come to the rear door 6. For the rear door, we have to remove the lock in order to get to the screw, so we have to remove the door panel and there are only two screw for the door panel. ![]() ![]() 7. remove the cable for the lock and unplug any wire for the power window or whatever u have. ![]() ![]() ![]() 8. after remove the door panel, u can unplug the wire and remove the lock ![]() ![]() 9. u will be able to see the screw after u remove the lock ![]() 10. remove the door handle the same way u do for the front door ![]() ![]() again run the LED wire through the wire tube into the car Now u can connect your LED wherever u want. I run the wire to the keyless dome light circuit, so when i open the door, this will come on Hope u guys like it
Yaris = <3
Drives: '08 Sedan - Flint Mica Join Date: Jan 2009
Do you have any pictures of them fully installed and turned on at night?
..:'; Nick ;':.. ============================== 2008 Yaris Sedan - Flint Mica ============================== Debadged Rear; Blue Interior Styling; Toyota Sports Pedals; AM Exhaust Tip; OEM Spoiler; Upgraded Speakers; Sony Xplod BT 2600 Deck; Infinity Basslink SUB/AMP in Trunk; 16" Konig Rims; 6000k HID Bi-Xenons; 6000k HID Fogs; NST Short Shifter ============================== |
Yaris = <3
That looks wicked!=D
![]() ![]() ![]() ![]() Drives: 2008 meteorite hatchback Join Date: Nov 2008
Where was the keyless dome light circuit in your car? What I mean is, how far did you have to thread the LED wire into the car?
It looks awesome, by the way.
- HOOOEY! That's one tahny little cawr! What the heck kinda toy is that? - A Toyota Yaris - A whut Yaris? |
╚══════════RN
+1
![]() ![]() ![]() Drives: 07 YARIS HATCH 5 DOOR Join Date: Apr 2007
[QUOTE=window_lee;378648]Finally I have time to take some pics of the DIY. Since my english is very poor, QUOTE]
Where you from? because your english is not bad at all compared to the people I talk to all day long! good DIY! might look into this very soon also!
![]() ![]() Drives: Black 5-Spd Sedan S Join Date: Aug 2009
dude that's awesome, and awesome pics, thank you :)
[QUOTE=the_boss;378990]I am from Hong Kong and now i am in Canada
Yaris = <3
[QUOTE=window_lee;379039]What part of Canada?
#11 | |
USAF_SrA_E-4
very cool seems easy but i am kinda inpatient for this kinda stuff. How lond did it take u?
absolutely BRILLIANT.
![]() ![]() ![]() Drives: 2008 Yaris sedan A/T Join Date: Oct 2008
How did you come up with this idea? Cause its B E Autiful.
![]() ![]() ![]() Drives: toyota yaris Join Date: Jan 2007
u can find these lights on the new bmw 135i twin turbo
^ this idea was also in the Vitz Hyper Rev. There's a lot of things you can do with LEDs, as y'all can see with the pictures.
| DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside | YarisSedan | DIY / Maintenance / Service | 73 | 03-11-2017 06:05 PM |
| DIY (08' USDM LB): Interior Light Color Change | revnull | DIY / Maintenance / Service | 37 | 05-21-2016 12:59 PM |
| DIY: Yaris LB Halo Led Projector Headlights | goku87 | DIY / Maintenance / Service | 37 | 11-15-2013 06:23 AM |
| DIY: LED side mirror installation | eTiMaGo | DIY / Maintenance / Service | 85 | 06-24-2011 11:48 AM |
