Old 06-05-2011, 09:26 PM   #1
Pacquiao
Drives: Yaris 5 Door Liftback
First Bar Disappeared @ 109 Miles...!!!
Is this a terrifically good sign? How soon does your first bar click off?
And I went with Blazing Blue...
I'm having regrets. I should have @#$%ing gone with Meteorite!
But the blue pulled me from the silver...
ARGH.
My feelings on Blazing Blue:
:rolle yes:
Pacquiao is offline   Reply With Quote
Old 06-05-2011, 09:31 PM   #2
enviri
enviri's Avatar
Drives: 2010 Yaris
that's really good. my first bar usually goes at 50-60 miles. lol. i have a SLIGHTLY heavy foot.
theres a pic of my meteorite just to spite you muahaha
Old 06-05-2011, 10:49 PM   #3
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
my first bar goes around 75 miles though I stop when the gas pump clicks once. not sure if that matters or not.
BEEF is offline   Reply With Quote
Old 06-06-2011, 10:55 PM   #4
brg88tx
Drives: 07 Yaris Sedan, Auto
me too, average 75, best ever was 83.
brg88tx is offline   Reply With Quote
Old 06-06-2011, 11:55 PM   #5
Pacquiao
The second bar disappeared @ 154 miles...
CANNOT WAIT TO SEE WHAT MY FIRST TANK BRINGS.
Then I can see when the first bar disappears on my second tank.
Old 06-05-2011, 10:55 PM   #6
The fuel sender stops registering after 11 gallons, so if the filler pipe was fully loaded, 109 is normal, as that can be 109 miles on over 3 gallons of gas. Here's an analysis I did a while back on the fuel sender response:
http://www.yarisworld.com/forums/sho...ght=fuel+level
Old 06-05-2011, 11:53 PM   #7
GanjaBabe420
GanjaBabe420's Avatar
Drives: 2008 Toyota Yaris Sedan
Send a message via AIM to GanjaBabe420
Thumbs up
nice..would be something mythbusters would do..lol
GanjaBabe420 is offline   Reply With Quote
Old 06-06-2011, 12:02 AM   #8
padre1964
padre1964's Avatar
Drives: I'm back !! 2012 Toyota Yaris
75 miles for me
best mpg so far, 46.1 !! Still shooting for 50 !
padre1964 is offline   Reply With Quote
Old 06-06-2011, 12:27 AM   #9
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
Look at the big picture: if you're odo shows about 400 miles at your next fill-up, then your'e fine.
Mine reads about 420 on it's final gallon.
Old 06-07-2011, 02:09 AM   #10
GanjaBabe420
Thumbs up
420! hahaha..
Old 06-07-2011, 08:54 AM   #11
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
90 kms winter 110 summer , Eco driving mode 126 kms best hwy trip 140 kms
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!!
"Horsepower is how fast you hit the object. Torque is how far you move that object.."
Old 06-07-2011, 12:00 PM   #12
BEEF
BEEF's Avatar
I burned my fist tank (didn't count it) since it was filled at the dealership. my next two yielded me 41.5MPG each.
my dad has a 2006 corolla and he regularly tops 40mpg though he does a lot of highway driving.
toyotas do great with mileage. I can't say for the trucks or the bigger cars but the smaller cars usually do really well.
Old 06-08-2011, 05:31 PM   #13
fearturtle44
Drives: S Flint Mica
As long as you drive conservatively, keep tires inflated to proper level, and are the only passenger in car, the Yaris should give you 35+ easily. I have a 07, Sedan, auto. Not much pick up speed but love the MPG.
fearturtle44 is offline   Reply With Quote
Old 06-09-2011, 02:27 AM   #14
Pacquiao
Fourth bar disappeared at 247 miles. What about you guys?
Old 06-09-2011, 04:45 AM   #15
YarisLover09
Drives: 2009 Yaris Hatchback
My first bar always takes forever to drop, coming in at around 100 each time. But then there's a huge dive until about halfway or so that goes by really quickly. I commute about 40 miles per day taking no special steps besides not driving like a maniac ( I have inflated tires to 42 psi all around) and I have averaged 38 mpg on my last six tanks. There is a lot of mileage to be had on this car but as for the fuel gauge accuracy it's only really good for knowing when to fill up.
YarisLover09 is offline   Reply With Quote
Old 06-09-2011, 05:30 AM   #16
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Without running the tank down to fumes you should be able to safely reach 400 miles per tank..
Old 06-11-2011, 10:55 PM   #17
SilverBack
Joey
SilverBack's Avatar
Originally Posted by GanjaBabe420 View Post
420! hahaha..
Yeah you know what's up
Old 06-04-2012, 01:18 PM   #18
jay cobbs
Drives: 2010 yaris sedan 4 speed auto
Arrow PLEASE READ THIS....YARIS inTO PRIUS SECRETS...ROAD WISDOM..
thr first bar is about 2.4 gallons. most blogs complain about the gauge is not " EVEN" when using fuel. about38-40 mpg sounds about right. My 2010 auto 4 speed gets that but heres how you might get more .... DONT OVER FILL STOP AT FIRST SHUT OFF PULL BACK SLIGHTLY TO LET VAPOR ESCAPE AND FILL TO NEXT SHUT OFF OR YOU WILL DAMAGE THE GASKETS AND NECK LINER ON THE TANK......ITS FULL>>>>DONT DAMAGE YOUR YARIS....IT"LL COST YOU BIG-TIME....
1. make sure air and oil filters are clean if not take to gas station and blow out air with air hose if still gray or brown...replace.
2. dino oil is fine check with trusted mechanic about swich to synthetic may only get 2-3 more per gallon .Weigh that with cost to see if thats good increse . or stick with Dino oil changes...do them like the manual says.
3. I dont over inflate my tires ever. mine are 195-15 size and the sidewall says 52 max. psi. Im at 37-38 psi ride is comfy. you can inflate to reduce road friction but tires will wear faster so keep them within the specs.. ...guess which is more expensive tires later, or gas right now.... ( answer...tires and rubber cost)
4. use what the epa calls "TOP TIER" gasoline. I get 3-5 miles a gallon better with chevron which has the techro "lean" additive now ...and union 76 is good for small engines too. they have less fuel fillers and more additives that make the engine run and stay cleaner....remember, its the long haul your engine is looking for...
FINALY... DONT BE A DRAG .... remove un-needed junk from the trunk. keep the spare if you must but with an auto club card or fix a flat can you might do better on milage. keep short errands togther to save gas.
LOOK AT YOU TUBE for eathier hypermiling tips or prius drive techniques ( which is why prius goes so far on gas... the dashboard is training the driver to "hypermile" and gives a video game to play for about 24K.
The Yaris 1.5L engine is the same type as the prius c and the drag weight and other specs are pretty close to your yaris...the main diffrence beside low resistance tires and a little trimer body ... IS YOU AND HOW YOU CAN MAKE YOUR YARIS INTO A PRIUS, PRESTO... WITH KNOWLAGE...NOT TECHNO TRICKS. BE PROUD OF YOUR YARIS....ITS THE SECRET LOVE CHILD BETWEEN A CAMRY AND A PRIUS. ITS STRONG like dad AND SIPS GAS LIKE MOM....ENJOY
Last edited by jay cobbs <posthistory.php?p=649284>; Today at 09:03 AM. Reason: real yaris secrects, yaris like prius, more mpg than before <report.php?p=649284> <report.php?p=649284>
jay cobbs is offline   Reply With Quote
Broke 50 MPG STC Fuel Economy Forum 71 12-13-2010 02:04 PM
Tokico Blues + TRD Springs &Sway Bar after 5k miles regal Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 12-18-2009 12:11 AM
How many MPB (miles per bar)? otterhere Fuel Economy Forum 56 07-15-2009 05:55 PM
Ultra Racing 23mm Rear Stabilizer Bar Loren Performance Modifications 62 05-18-2009 08:20 PM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-06-2008 12:37 AM
