![]() Drives: Yaris 1.3 07 Join Date: Oct 2011
Finally i installed Cold Air Intake system on my 1.3 yaris ! K&N
Hi everyone ..
Finally i installed Air intake system "K&N Sport Fillter" in my 1.3 sedan yaris it has a coooool sound after 3000 RPM but i don't feel any improvement in acceleration ! ! ! someone told me that the air mass sensor need readjustment but i don't know how could i do it ? ? is that true ? there's some pics during installing .. ![]()
Not quite a noob
Drives: e46 325 Join Date: Jul 2009
The MAF may benefit from being cleaned, there is no adjustment for it. To clean the MAF use an electronics cleaner in a spray can
you thought that the dust affected the sport air filter ? ?
Not quite a noob
Mass Air Flow sensor.
MAF = mass air flow (sensor)
it is the sensor that is in the new tube. it is held in by two screws and has a wiring harness on it. in your picture, it is between the two hose clamps. on the nice shiny hose, it is the dirty dusty thing that you put back on it. |
yes i got it ... but you thought that the dust could affect the sport air filter ? i could feel any improvement in acceleration if i well cleaned it ?
Form>Function
Drives: 07 Flint Sedan Join Date: Dec 2009
Dirtiest engine bay ever. And 1.3?
![]() ![]() ![]() Drives: 2010 Prius, 2007 Yaris Sedan Join Date: Oct 2009
did you disconnect the negative from the battery to let the ECU reset?
#9 | |
:( i'm gonna clean it ,, but i did not do it before because someone told me that it's too bad if you cleaned your engine and you don't have to do it
and yes sir it's 1.3 Quote:
i disconnected it and reconnect after about 10 min ! NO change NO improvement ! |
Whoever told you not to clean your engine is a dumbass.
#11 | |
If you unscrew those 2 phillips and disconnect the sensor, you can pull it out. Then you can clean the little shiny part in the sensor that is shown in the picture attached. It usually gets dirty and is a good idea to clean it every now and then.. esp with a filter like you have there. Those filter doent filter out as well as the paper ones do, but thats for air flow reasons.. I would disconnect your battery again, and clean the MAF sensor. then put it back. Your ecu should reset your learned driving habbits.. You MAY feel a throttle response difference but unlikely. But it doesnt hurt to clean it.
Form>Function
I thought in 07 the yaris sedan was only available in 1.5L
http://en.wikipedia.org/wiki/Toyota_Vitz right...
#13 | ||
right you are
#14 |
A new intake will probably only give an extra 1-2 hp over stock, which you probably wont even notice. It's never a bad idea though to clean your MAF. Especially with how dirty your engine bay is.
#15 | |
guys : should i change the filter place ? or that's good place ? i would like to move it slightly left and slightly down |
#16 | |
disconnecting the battery will reset the ecu. the ecu learns driving habbits and compensates. being that you already disconnected it to begin with, you dont have to. unless u get a code. Am I the only one about this thread
#17 | |
Form>Function
#18 |
Form>Function
Is this why you are so graciously giving yours to me? lol
| 2012 Camry | Kal-El | Off-topic / Other Cars / Everything else Discussions | 26 | 10-02-2011 09:20 PM |
| FS: AFE Air Intake System (Cold Air Intake) | jjbG35yaris | Items for Sale by private party | 7 | 04-01-2011 02:58 PM |
