Old 10-12-2011, 03:54 PM   #1
monchyxb
Drives: scion xb
Custom Intake manifold!
I just bought a corolla 2000 intake manifold with the flange made for the 1nz. Also adapted a corolla 2zz throttle body. Did some powder coating and mounted it today! had to improvise for the moment with the vacuum hoses but I will fix this tomorrow... right now I wanna test this! here are some of the pics.
File Type: jpg 310717_10150795667160184_812920183_20390746_1744757826_n.jpg (69.7 KB, 643 views)
monchyxb is offline   Reply With Quote
Old 10-12-2011, 06:08 PM   #2
result should be interesting - no-plenum design
Old 10-12-2011, 06:50 PM   #3
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
What's the throttle body flange inner diameter? I've been thinking I want to try and fab up my own to get the full 1ZZ tb diameter instead of necking it down to stock.
Old 10-12-2011, 10:05 PM   #4
monchyxb
Drives: scion xb
I think its a little bit more than 2.25". Huge response when going WOT. If you want to do it you'll have to make a custom flange since the throttle is 4 bolts instead of 3.
Old 10-12-2011, 10:36 PM   #5
CrankyOldMan
Crap, I knew there was a catch! I thought there were some drive-by-wire TBs with three bolts, but looks like only the cable driven ones have 3. Does it look like the end of the plenum could be cut off and re-welded with a new flange? The only pic I could find online was a side view that doesn't show the TB port.
Old 10-13-2011, 09:55 AM   #6
monchyxb
Drives: scion xb
Yes you could cut were the throttle is bolted on and make a flange for the other throttle and weld it. It has the space to do it! Or you could use the throttle that comes with the manifold which is bigger than the 1nz.
Old 10-13-2011, 10:06 AM   #7
CrankyOldMan
The yaris uses electric throttle control (DBW), not a cable like the xB. There are plenty of 1.8L throttle bodies for the 4-bolt pattern with DBW, but none that I can find with the 3-bolt pattern and DBW.
Old 10-12-2011, 07:55 PM   #8
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Cool! Is this a one off or is someone making these?
Old 10-12-2011, 08:19 PM   #9
thread should go in Performance Mods, no?
Old 10-12-2011, 08:25 PM   #10
netz2008
Drives: 2008 hatchback
Wow, drive by cable? Second Yaris I know that uses that!
I've got the 1zz throttle body, and my intake manifold is ground down to the diameter of that throttle body (big difference between a stock intake manifold and port matched btw)
netz2008 is offline   Reply With Quote
Old 10-12-2011, 08:34 PM   #11
Bluevitz-rs
^ his "Drives:" is an xb so why wouldn't it have a throttle cable?
Old 10-12-2011, 09:58 PM   #12
monchyxb
Drives: scion xb
People here in Puerto Rico are doing it for the 1NZ.. I have seen a couple on a classifieds web page from here.. I bought it for 150 from a guy who claimed around 8hp on an aspirated motor. I felt more power just bolt on, but some A/F problems at idle the motor turns very lean so next week I'm off to the dyno to do a tune and see the numbers.
BTW how do I change this to performance mods??? Sorry noob here!
Old 10-12-2011, 10:44 PM   #13
Even if it doesn't make much power, it's sexy as hell; I'd rock that.
Old 10-13-2011, 09:59 AM   #14
monchyxb
Drives: scion xb
It does look very sexy! Thanks!!
Old 10-13-2011, 04:39 AM   #15
Nanoss22
Drives: Yaris sedan 10 std...
Uff PR lo hace mejor a mi me venden.una en 50 pesos pero.hay q hacerle la chapa mas lo del trotel ... De q parte eres???
Nanoss22 is offline   Reply With Quote
Old 10-13-2011, 09:58 AM   #16
monchyxb
Drives: scion xb
From Mayaguez! 50 bucks sounds nice.. but the expensive part here is making the flange to make it fit in our motors, The guy who I bought it from said it cost him 100 to make the flange :/
Old 10-14-2011, 09:59 AM   #17
CrankyOldMan
Ok, found some info on the 1ZZ.
* 87.5 mm cylinder spacing.
* 41 x 413 mm runners
I measured the flange on the manifold and found that the runner spacing is also 87.5 mm, and the ports are 35 x 52 mm elliptical.
Update:
I found some info on the 1NZ cylinder spacing:
cylinder bore: 75mm
cylinder wall thickness (between bores): 8mm
cylinder pitch: 83mm
That should make the header pitch 83mm as well. Now to figure out the opening dimensions and bolt locations...
Old 10-18-2011, 09:50 PM   #18
Viperoni
Drives: 2005 Toyota Echo
Maybe that type of manifold works better for boosted cars than N/A, I had a buddy of mine (with a B.Sc in ME, built an IM as a part of his schools Formula SAE team, and worked for GM) tell me that it's tough to implement properly on N/A cars and a typical runner+log manifold works better.
2006 Saturn Ion Redline
Custom Short Ram Air Intake Problem laxsaint99 DIY / Maintenance / Service 10 04-27-2011 02:28 AM
Custom Intake manifold/w 1zz tb / direct port nitrous blacksandiegovitz Items for Sale by private party 28 11-23-2010 09:57 PM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 08:05 PM
My Custom Intake RacerFreakXXX DIY / Maintenance / Service 7 12-21-2008 08:32 PM
