Old 06-03-2007, 12:03 PM   #1
c-one yaris
c-one
Send a message via AIM to c-one yaris
17x7 +38 rims with 215/45/17 tires
I plan on getting a set of 17x7 +38 rims to go with my 215/45/17 tires, but I was curious if this would fit with NO RUB. -Anthony
c-one yaris is offline   Reply With Quote
Old 06-03-2007, 12:58 PM   #2
don't know, I had issues with a 205/16/50 tire.
http://www.yarisworld.com/forums/showthread.php?t=6147
Is your car lowered?
Old 06-03-2007, 06:06 PM   #3
kimona
kimona's Avatar
Drives: 2014 White VITZ
I think if you don't lower your car, you should be fine.
But, 7's with a +38mm offset and a 215 tire is pushing the front package past the outer limits. Your fronts are going to stick out just a bit which does look kinda goofy. But, some guys don't really care.
BTW, what wheels are you looking at?
Can't you find something you really like with a +42mm or more offset.
I know it's tough to find exactly the right wheel!
Old 06-05-2007, 08:05 AM   #4
c-one yaris
c-one
No
Old 06-05-2007, 08:07 AM   #5
c-one yaris
c-one
C-ONE SA-70. I'll go with the +43. the bolt pattern is 4x100 right?
Old 06-05-2007, 09:26 AM   #6
kimona
kimona's Avatar
Yeah, the Yaris is 4x100.
The Weds SA-70 is a nice Japanese wheel, but must be expensive and probably takes a bit of time to get.
Not sure, but I think you can stagger the offsets with that wheel if you want.
A lot of Japanese guys do that.
For example, 43mm up front and 38mm rear. Just a thought.
Old 07-18-2007, 04:42 PM   #7
c-one yaris
c-one
ok... i'm going to get the trd lowering spring and maybe, just maybe the trd shocks and struts.
i want to know if the 215/45/17 tires will fit with a +42 offset?? will any feed back is great. thanks guys!
Old 07-19-2007, 01:40 AM   #8
Black Yaris
der Zeck
Black Yaris's Avatar
yup it will fit, long as you don't mind the constant rubbing when turning, after you lower it, it will probibly rub on bumps and while turning.... but nothing some inner fender modification can't fix
Old 07-19-2007, 01:41 AM   #9
Black Yaris
der Zeck
215/45R17 is an awfully tall tire compared to the stock
Old 07-19-2007, 09:45 AM   #10
kimona
kimona's Avatar
T-Sport: OEM 17x6.5, ET51, 205/45/17.
215/45/17's are only 3/10ths of an inch (1.6%) taller than OEM, so height should be no problem whatsoever.
You want to run 17x7, ET42. With this wheel, 205 rubber may be tucked by a few mm's up front. If you run a 215, your front tire may stick out a couple of mm's which just looks stupid!
You may be fine with either setup at stock height; however, you want to lower your car, and that is where you may run into problems.
To avoid rubbing problems, you should probably run 205/40's up front, and 205/40's or 215/40's in the rear.
Old 07-19-2007, 04:58 PM   #11
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
You should run 205/40/17 (slightly smaller (what I use)), 205/45/17 (slightly larger), or 215/40/17 (exact stock replacment). A 215/45/17 is really tall; you WILL rub if you lower your car, maybe even without lowering.
PetersRedYaris is offline   Reply With Quote
Old 07-19-2007, 08:33 PM   #12
kimona
kimona's Avatar
205/45/17 is OEM (T-sport) @ 24.3", and this is the size you should run if you don't lower the car.
215/45/17 @ 24.6" is not much taller (1.6%), and it won't make any significant difference in height whatsoever; you'll just have a wider footprint. If you don't lower your car, you would be fine, but the sidewall may poke out a bit up front with a 7" ET42mm, and will definitely stick out with with ET38mm.
So, as Peter indicated above, you should run 205/40/17's if you plan to lower your car. You can stagger the sizes front to rear if you like. Staggered wheel widths, offsets, and/or tire sizes are a common application on the Vitz in Japan.
You could run 205/40's up front and 215/40's in the rear. This would look excellent and compensate (5mm's) for the obvious FR/RR difference.
Old 06-18-2012, 09:29 PM   #13
Jerkratt
Jerkratt's Avatar
^ I ran motegi's 17x7 front 205/40/17 back 215/40/17 when i had the 215's in the front I rubbed on turns and bumps as well as the inner fender... I had and still have been running TRD Sportivo shock and strut set with the TRD lowering springs
"It hurts more when its wet"
Old 06-19-2012, 12:55 AM   #14
KSIbucky
KSIbucky's Avatar
Drives: 2007 Yaris manual dark silver
Send a message via AIM to KSIbucky Send a message via MSN to KSIbucky
Go 215 40r17 It's a .98 difference compared to 1.28 with the 45
7 Color Tach
Fujita Intake
Momo pedals Shift knob and boot. Full TRD SSK.
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
KSIbucky is offline   Reply With Quote
Old 06-19-2012, 03:59 AM   #15
Holy thread revival batman!
FS Brand New Stock rims w/ Tires FlintS Items for Sale by private party 10 09-24-2007 09:22 PM
FS: 17'' Motegi MR7 Rims and Khumo Tires Sabretooth Items for Sale by private party 11 07-02-2007 03:55 PM
Need help when ordering my tires and rims thomasward00 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 04-26-2007 10:40 PM
FS: 07 yaris RS stock rims n tires thegame11 Items for Sale by private party 5 04-15-2007 02:25 PM
New rims - old tires littlecarlove Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 11-15-2006 07:51 PM
