Old 05-05-2012, 10:14 PM   #1
patm
Drives: 2007 yaris sedan
This mod makes the headlights turn off when the ignition is turned off
Has anyone tried this mod. If yes are you experiencing any problems.
http://www.yarisworld.com/forums/sho...gnition+turned
Thanks, PatM
patm is offline   Reply With Quote
Old 05-06-2012, 01:02 AM   #2
Qmobile
that's right I went there
Qmobile's Avatar
Drives: '08 Blazin' Blue,'10 Dark Red
do u mean if all the lights are on (i.e. headlights and tail lights)? I don't belive anyone has.....be cool though
Mods: 15" SSC rims, TRD Exhaust, TRD Sway bar, TRD oil filler, TRD rad. cap, TYC tails, Debadged, Painted engine cover, Stock spoiler, Stock mud gaurds, OBX pedals.
suggestions always welcome
Qmobile is offline   Reply With Quote
Old 05-06-2012, 04:39 PM   #3
patm
there is a mod that makes the headlights turn off when the ignition is turned off on this website
Has anyone tried it.
Old 05-06-2012, 05:23 PM   #4
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
The guy that did the DIY did, obviously. As far as I know he hasn't had any problems with it.
Old 05-06-2012, 06:50 PM   #5
new-yaris-owner
Drives: Toyota Yaris LE HB 2008
I'm not concerned of the headlights when the ignition is turned off, but I am concerned of turning the headlights off on a sunny day and turn them on when at dark.
On my Mazda Protege 2002, I only need to lift a click on the handbrake and I can drive without headlights when I want.
Is that possible with a Yaris ?
new-yaris-owner is offline   Reply With Quote
Old 05-06-2012, 07:03 PM   #6
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
Yep, just disable them: DISABLED DayTime Running Lights How To- 2007 Yaris!
Old 05-06-2012, 09:54 PM   #7
I am the one who documented the DIY. I have not had an issue since I did the mod, back when I posted it.
Old 05-07-2012, 12:06 AM   #8
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Did it about 6 months after I had the car. Not a problem at all.
I will say though in canada it is a law you must havs drl's. At least I am almost positive I have read canadian members saying that.
Colin Chapman disciple
Old 06-25-2012, 12:14 AM   #9
new-yaris-owner
Ok great for deleting the DRLs...
but will I need to reconnect the DRL relay if I want to drive at dark ???
I need to understand before doing the surgery that if I remove the DRL relay, I will be able to do something other than reconnect the relay to drive by night.
Thanks !
Old 06-25-2012, 12:25 AM   #10
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
Thanks !
No, just turn your lights on when it's dark out!
All you'd be doing is disabling the daytime running lights, everything else would be like usual, if you want your lights on, turn them on.
Old 06-25-2012, 11:37 PM   #11
Sir A.Y. Atoyot
Sir A.Y. Atoyot's Avatar
Drives: '08 5-door
You bet we do. Best way to attract attention from cops that I know of - an obvious lighting violation on a late model car. Almost as good as burning donuts in the police station parking lot.
Sir A.Y. Atoyot is offline   Reply With Quote
Dashboard lights turn off when I turn use headlights patate15 DIY / Maintenance / Service 7 07-05-2020 04:05 AM
DIY - Headlights off with the Ignition Switch CTScott DIY / Maintenance / Service 46 11-03-2018 09:42 PM
AC makes a rattling noise when turned on. gabriel2012 DIY / Maintenance / Service 8 07-12-2011 07:03 PM
Will local bay area members please stand up! YarisSedan California 264 07-29-2009 12:53 AM
2007 Yaris Sedan S Ignition won't turn koharegistrar1 DIY / Maintenance / Service 7 12-24-2008 09:34 AM
