Old 07-22-2012, 07:08 AM   #1
willygoodness
Drives: 09 yaris hb
check engine light, engine turns but not start
Hello all
I moved my car this morning about 5m, just turn on and off pretty quickly. This evening popped the key in, check engine light is on, the motor turns over but doesn't start up
desperation lead me to disconnect the battery for a couple hrs! ... same problem
58000km coming up... 09 manual hb 1.3
Also i went to a small petrol station and put half a tank in from nearly empty :/ but i've been driving to work and around town the last 3days
any ideas/suggestions to fix would be fantastic?
willygoodness is offline   Reply With Quote
Old 07-22-2012, 08:15 AM   #2
ciscobear
Drives: Toyota Belta
maybe a dead battery?
ciscobear is offline   Reply With Quote
Old 07-22-2012, 08:45 AM   #3
willygoodness
Drives: 09 yaris hb
mmm maybe. i didn't check the headlights. but stereo, brakes and indicators work.
hrm. well i've only got hid's as headlight/fogs so they still turn on and heat up as usual
engine turns over rather vigerously aswell. i'll find a multimetre and check the battery voltage in the morning.
my guess is going to be failed fuel pump or ?clogged filter? maybe. hrmph. altho. not sure on how to check for broken fuel pump tho.
sigh, broken stuff isn't as fun as working stuff
Old 07-22-2012, 09:16 AM   #4
sex
sex's Avatar
Drives: 09 5DR
Do you have an immobilizer? Have you tried the other key?
sex is offline   Reply With Quote
Old 07-22-2012, 09:55 AM   #5
willygoodness
Drives: 09 yaris hb
^^ naa just the factory car stuff.... unless ur in my area then i have a fantastic thing in there.. i will try the other keys in the morning for sure.
but the motor is turning over and if i leave the key on, the motor keeps trying to start and stops after a few seconds.. The main key i use still unlocks the door tho. but hmmm I hope it works. cheers (Y)
Old 07-22-2012, 11:09 PM   #6
willygoodness
Drives: 09 yaris hb
<a href="http://s1216.photobucket.com/albums/dd362/willygoodness/?action=view&amp;current=208935_10150930441426105_ 2128548059_n.jpg" target="_blank"><img src="http://i1216.photobucket.com/albums/dd362/willygoodness/208935_10150930441426105_2128548059_n.jpg" border="0" alt="Photobucket"></a>
is my airflow meter ok? Is the brown goop on the prongs ment to be there?
Old 07-22-2012, 11:09 PM   #7
willygoodness
Drives: 09 yaris hb
Old 07-23-2012, 12:33 AM   #8
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Looks clean as a whistle.
Don't mess with the "goop" on the prongs.
It belongs there.
Old 07-23-2012, 12:51 AM   #9
willygoodness
Drives: 09 yaris hb
sweet. the goop stays :)
I did put some carby&throttle body cleaner on the butterfly in hope that it would give it a lil bit of a kick start.
tried to start up again, 3 key turns and 4th one with the accelerator all the way down and started up.
so I must of put in some reallybad fuel :/
Old 07-23-2012, 10:50 AM   #10
ciscobear
or probably the ECU has some bad/blown capacitors. Could be fuel pump as well, get that checked out.
Old 07-23-2012, 05:10 PM   #11
willygoodness
Drives: 09 yaris hb
^^ ok I shall do
thanks all
yaris won't start, engine truns over but won't start. zara616 General Yaris / Vitz Discussion 16 09-05-2021 11:39 AM
Check engine light flashes during high reving AlphaFox DIY / Maintenance / Service 40 08-21-2007 01:43 PM
Check Engine "Injector failure Code" YarisPR DIY / Maintenance / Service 14 03-04-2007 08:13 PM
