![]() Drives: 2007 Toyota Yaris Sedan Join Date: Nov 2018
'07 Transmission Problems
Hello everybody! This is my first post to the forum. I just bought my first Yaris 2 weeks ago, an '07 sedan with 130k and an automatic transmission. I put about 50 miles on it after purchasing it private party, and started having an odd issue with the transmission. When I really step on the gas, regardless of speed/gear, the car refuses to shift and hits the rev limiter repeatedly, causing the car to jerk and lurch until I let off the pedal. If I accelerate slowly, it shifts normally.
While I live in a colder climate and it is borderline winter, this is occurring after the cold symbol from the dash is gone, and the car has been driven substantially before hand. I've read every post I can find on here about transmission problems, and haven't been able to gain much insight on the issue. Any help is appreciated. I'm relatively mechanically inclined, but I don't have the resources or time to drop a tranny. I have a local shop I trust for issues I can't handle, but if I don't have to take it there I don't want to ![]() Thanks in advance!!!! |
![]() ![]() ![]() ![]() Drives: No longer own a yaris :( Join Date: Mar 2012
Have you checked the transmission fluid level? Low tranny fluid is probably not the issue, but it's worth checking just to be sure. I've seen auto tranny cars slip like the bands are worn and they were just low on fluid.
I'm a hermit named Lee |
That was the first thing I checked. Clean, clear, and full.
That sucks. It's likely something internal like the bands or maybe torque converter? My yaris is a manual, so I don't know what the life expectancy for the auto is, but I'd think it would be more than 130k before major issues.
You won't find anything here by searching. The auto tranny has proven to be essentially bullet proof with very little reported issues. If, as you say, the fluid is full and clean and your problems exist at normal operating temps, then I'd say a trip to the shop is in order.
What's going to suck is the potential of a repair in this situation being essentially what market value of the car is. Sent from my EML-L09 using Tapatalk
#6 | |
#7 | |
Anything spinning is going to start to wear down over 100k so I'd check water pump, alternator, wheel and suspension components. The motor is pretty reliable as long as you keep up with the oil.
Well, my transmission guy couldn't find a single thing wrong without the transmission. Any other suggestions?
Any codes?
Looks like you found an honest mechanic. Just drive so it doesn’t act weird. I think you dodged a bullet because many mechanics would take you to the cleaners. Just drive carefully and see what happens.
How cold is it there now? Perhaps that’s part of the problem if it’s very coldr? I was just back in upstate New York where it’s very hilly and my transmission didn’t shift as smooth as it does in New Jersey where it’s very flat. I’m not worried at all .
![]() Drives: '10 Hatchback Join Date: Dec 2016
Bad speed sensor(s) that read the engine or transmission revolution will cause all kinds of weird things to happen, without throwing any codes. Never heard of these going bad on Toyotas but it is worth trying.
| Shifting Problems Automatic Transmission | Surubi | DIY / Maintenance / Service | 3 | 03-14-2016 01:52 PM |
| Transmission problems ???:( | MaXx0909 | DIY / Maintenance / Service | 9 | 04-25-2014 03:36 PM |
| NEW TRANSMISSION PROBLEMS HELP! | silaypalmer13 | DIY / Maintenance / Service | 8 | 03-29-2009 02:43 PM |
