Old 08-25-2012, 06:25 PM   #1
b20vteg
no show, no go :(
b20vteg's Avatar
Drives: 2012 yaris 3dr hb
rim fitment with stock tires 175/65/15
how wide are stock steelies? 5.5"? 6"?
would stock rubber wrap around a 7" wide rim without stretching too much? even if it stretches, how well do stock rubbers respond to stretching?
b20vteg is offline   Reply With Quote
Old 08-25-2012, 07:26 PM   #2
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
Stock is 5.5
What size are your tires? I have 185/60 and that is not a stretch 185mm is 7.3".
Old 08-25-2012, 07:51 PM   #3
b20vteg
no show, no go :(
b20vteg's Avatar
Stock is 5.5
on the 2012s, stock tires are 175/65/15s i think? have to double check outside...
Old 08-25-2012, 08:02 PM   #4
1.5
Form>Function
1.5's Avatar
Yea that wont be a problem. I ran 195/50 on an 8" and just ordered new 175/50s to run on that 8". That's a stretch.
Old 08-26-2012, 12:22 AM   #5
b20vteg
no show, no go :(
b20vteg's Avatar
sweet, thanks bro! :)
Old 08-26-2012, 09:44 AM   #6
1.5
Form>Function
1.5's Avatar
Np GL!
Old 08-26-2012, 03:57 PM   #7
Yeah, something with that big of a profile isn't going to stretch. Furthermore, I personally wouldn't even try stretching tires that have been mounted and used on another set of rims already.
Old 08-26-2012, 06:41 PM   #8
b20vteg
no show, no go :(
b20vteg's Avatar
do you mind elaborating on that? not really understanding what you're trying to say?
Old 08-26-2012, 07:07 PM   #9
1.5
Form>Function
1.5's Avatar
Profile is thickness, so the 65 mm is going to be hard to stretch, the rubber is going to want to stand up instead of lay down.
I disagree with his comment about stretching used tires. I have seen it done multiple times. I think his stance is that the tire has flexed, worn, and molded into a certain shape based on how it has previosuly rolled. Now you are trying to force it into a different conflicting shape.
Old 08-26-2012, 07:31 PM   #10
Profile is the side wall size. So taking 175/65/15 for example:
175 is the width of the tire measured in millimeters (mm).
65 is the side wall size in regards to the first number. It is not measured in mm, but in %, so 65% of 175mm is the side wall profile.
15 is the rim size measured in inches.
Being such a large profile, stretching it will take a rather wide rim as there is more rubber to "stretch."
But yes, tires get broken in, so if it is used on a properly fitting rim and is aged, the side walls may have started cracking, so stretching it would not be safe.
Old 08-26-2012, 07:37 PM   #11
By used, I mean used, not test fitted and then unmounted.
Old 08-26-2012, 08:08 PM   #12
1.5
Form>Function
1.5's Avatar
Thanks for the correction on profile size. Learn something new all the time. I always thought it was mm.
Old 08-26-2012, 08:34 PM   #13
b20vteg
no show, no go :(
b20vteg's Avatar
thanks for clearing that up lazagna! the main thing i'm concerned with is whether or not my stock tires would stretch on a 7" wide rim, and according to 1.5, i should be ok. :)
Old 08-27-2012, 02:28 AM   #14
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
for reference
You won't have to worry about stretching you stock tires onto a 15x7 wheel. It will be very minor. Here are my pics for reference. Hope this helps.
Tires are 175/50/15
15x7 (sorry, not a very good pic)
15x7.5
15x8.5
Old 08-27-2012, 03:41 AM   #15
No problem. That's life, you're always going to learn something new everyday, I know I do.
Old 08-27-2012, 03:42 AM   #16
This is the closest thing I can find to 175/65/15
185/60/15
Old 08-27-2012, 03:44 AM   #17
And for anyone who is curious about stretched tires, you'll most likely find the tire specs over what ever width rim you're curious about here:
http://tyrestretch.com/
Old 08-27-2012, 07:55 AM   #18
1.5
Form>Function
1.5's Avatar
Best website ever I use it all the time
Best replacement tires for stock '09 TheKindG Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 01-18-2011 05:29 PM
Need help on Rim and Tires alan1828 Canada 3 09-30-2010 04:24 PM
FS Brand New Stock rims w/ Tires FlintS Items for Sale by private party 10 09-24-2007 09:22 PM
FS: Stock tires on steelies spkrman Items for Sale by private party 9 04-12-2007 07:45 PM
Stock wheels and tires rwseattle Items for Sale by private party 0 02-04-2007 10:05 PM
