Old 08-28-2012, 05:18 PM   #1
david_827
Drives: 07 Yaris Sedan
Spin out and engine shutoff?
I didnt know which forum to put this in, so my apologies if this is the wrong place. So earlier today, it was raining pretty bad. After leaving the gas station i entered the rotary. As i was going around the rotary, i could feel myself start to hydroplane a lil. When my rotary exit came up i went to take it, and instead, ended spinning 180 degrees, counterclockwise. Scared the shit outta me. Luckily i didnt hit anything After when i got my bearings and went to drive off, the engine was off, but the key was still in the "on" position. Is that normal? i turned the car off and started it again, and it started right back up and no dashboard indicators were on. i pulled into the nearest parking lot and popped the hood. Everything looked fine, and nothing was leaking or disconnected is there any possibility that i could've damaged something?
david_827 is offline   Reply With Quote
Old 08-28-2012, 05:31 PM   #2
There isn't an inertial shutoff, so the reason for the stalling could be fuel starvation, particularly if the tank was low, as the Yaris gas tank doesn't have any baffles to keep the gas from sloshing.
I assume it's an AT, otherwise the other likely stall cause could be stomping on the brake without pressing the clutch.
Old 08-28-2012, 05:44 PM   #3
david_827
yes its an automatic. fuel starvation? i had just filled up prior to incident....
Old 08-28-2012, 05:44 PM   #4
david_827
could a full tank of fuel have sloshed around enough to cause the starvation?
Old 08-28-2012, 05:56 PM   #5
No. If it was full, that wouldn't do it.
Old 08-28-2012, 05:57 PM   #6
david_827
damnmit so chances are i may have damaged something??
Old 08-28-2012, 06:03 PM   #7
I don't think so. Since it started back up and doesn't have the MIL lit, chances are that you didn't do any damage.
Old 08-28-2012, 07:08 PM   #8
david_827
Thats good to know, thanks alot CT!
