![]() ![]() Drives: 07 hatchback Join Date: May 2012
broken bolt extractor
So I changed my sparkplugs a while back and almost broke 2 bolts tightening down the coils.
well yesterday I double checked they were all tight and broke one off in the head. So I grabbed a screw extractor and drill bit and got the screw extractor in and then it broke. I spent probably 2 hours trying to drill a hole for the bigger (correct) size screw extractor but that just wasn't working with how much harder the broken extractor was. I eventually ended up getting out the dremel and grinding the hole back centered and then grabbed a carbide tipped drill bit intended for glass. This ate right through the extractor and got me a nice hole for the correct screw extractor to bite into and the bolt came right out. So lesson is use a carbide tipped bit if you break a screw extractor in a bolt. |
#2 | |
Lesson learned is use proper torque amounts for bolt/application.
I'm surprised that you were able to cut the broken extractor with a drill bit. Usually it's game over at that point. Did it actually drill a hole into the extractor or just kind of break it?
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 09:14 PM |
| Warning - Broken control arm bolt! | CB900F2 | DIY / Maintenance / Service | 460 | 08-23-2020 06:54 PM |
| Left lower suspension arm rear bolt broken. | Kramruuk | DIY / Maintenance / Service | 1 | 07-07-2012 06:42 PM |
| How to replace a broken wheel stud | Rami yaris | DIY / Maintenance / Service | 4 | 06-28-2012 06:34 PM |
| 2 bolt alternator, lower pivot bolt | jstantherprsn | DIY / Maintenance / Service | 7 | 04-12-2011 11:02 AM |
