Old 09-30-2012, 03:17 PM   #1
09sedan
Drives: 2009 yaris sedan
Sedan Plastic window Panel
anyone know where i can buy a set of these? i want to have an extra pair so in case i f*** up mounting the tweeters i wont have 2 holes in the interior.
car is a 2009 N/A market sedan
( the black piece of plastic between the window and the A pillar)
09sedan is offline   Reply With Quote
Old 09-30-2012, 03:32 PM   #2
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Yes...give me a few to find the part number. I've ordered these before for my sail panel install...
(I'm sitting at the barbershop, it'll be a few)
67491-52140
GARNISH, FR DOOR LWR
15.69
67492-52130
15.69
This should be the sail panel. I'm seeing all pics to reflect that. They're fairly inexpensive.
― Thomas Paine
Old 09-30-2012, 09:37 PM   #3
09sedan
ty, i got no money atm to throw in a 4 channel, so im gonna grab a component set and mount my tweeters there and just power them off the head unit till i save up some more money.
Old 09-30-2012, 09:43 PM   #4
09sedan
Old 09-30-2012, 11:10 PM   #5
sqcomp
Roadrunner Jr.
sqcomp's Avatar
If for whatever reason you do "mess up" the mounting, you can in most cases save the sails. Before you throw them away shoot pics and we can help you rescue them.
― Thomas Paine
Old 10-01-2012, 12:18 AM   #6
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Gives you a good excuse to carbon fiber wrap them
Old 10-01-2012, 07:17 PM   #7
09sedan
nah i was thinking buy a 2nd pair, use a circular hole drill bit and just drill out hole for tweeter, and probably super glue it or use plastic adhesive to secure the tweeter to the panel. whats the maximum depth for a tweeter to fit in the sail panel?
Old 10-01-2012, 10:56 PM   #8
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Depth depends on whether you have power mirrors...There's a grey cord that comes up into the mirror that has a plastic grommet that invades into the sail panel space. Aside from super glue, I'd use ABS plastic. The CA glue is brittle. Always think about "gluing" using the same material you're bonding to...hence why I say ABS plastic. Otherwise you'll have two different materials with different behaviors under hot and cold conditions. For instance fiberglass over plastic can contract and expand differently causing cracking (I know this from first hand experience). I'm dealing with that using my "old" a-pillars.
I've got HAT Pro R2s up in the sails but they're also built out a bit to give some angle.
― Thomas Paine
Old 10-02-2012, 03:03 PM   #9
09sedan
yea i have power side mirrors.
Bought A Used 2010 Yaris Sedan & Customized! us13doolittle New YARIS Purchase Forum 8 10-14-2012 06:16 AM
i've stopped thebarber Off-topic / Other Cars / Everything else Discussions 37 12-30-2011 06:52 PM
