Old 09-28-2012, 11:31 AM   #1
ThomEdwardDudgeon
Chainsaw
Drives: 2012 Yaris Sedan
Help! CAI throwing codes
I just installed a Spectre CAI unit (with an MAF sensor connector on my 2011/12 Sedan. Installation was easy, except for the MAF unit, which was kinda guess as you go. I positioned the sensor in the same position as it was on the OEM, and all connections are tight-but it runs like poop! I took the whole thing back off, put all the OEMs in place and now everything is fine. Can anybody help?
ThomEdwardDudgeon is offline   Reply With Quote
Old 09-28-2012, 11:35 AM   #2
goliath1812
goliath1812's Avatar
Drives: 2010 Prius, 2007 Yaris Sedan
Did you disconnect the battery to let the ECU re-learn after you installed the CAI?
goliath1812 is offline   Reply With Quote
Old 09-28-2012, 11:37 AM   #3
I haven't seen the Spectre one for the Yaris, but the typical issue with generic aftermarket ones is the pipe being the incorrect diameter. The MAF sensor is calibrated to the diameter of the pipe it is mounted to. If you change that dimension then its data and hence the ECM's interpretation of airflow into the engine is skewed.
Old 09-28-2012, 11:52 AM   #4
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
It looks pretty standard...
They go for around $70. If the filter is oiled maybe the MAF got fouled.
Hey, does the MAF have a direction? Can it be installed backwards? I'd yank the battery cable to reset the ECU, see what happens and go from there.
New aFe CAI = CEL with P0101 Error randydid Third Gen Yaris General Discussion 10 01-16-2012 10:24 PM
Throwing a CEL after adding an intake and headers Mister Z Performance Modifications 19 07-28-2011 07:33 AM
FS: BOMZ CAI posaunemeister Items for Sale by private party 8 10-03-2009 02:02 PM
TRD CAI & TRD Qiuck Shift Polar Items for Sale by private party 7 08-02-2007 06:03 PM
