Old 04-17-2012, 03:07 PM   #1
Echostatic
Drives: 2007 Toyota Yairs
Hatchback liftgate post (pneumatic)
I was just loading my '07 Yaris and tried to close the hatch when I heard a "DUNK" and it fell shut. Inspection revealed that the left pneumatic arm's anchor (on the trunk side) had popped out.
Has anyone had this happen? Better yet, anyone have an easy fix? It'd be great not to have the trunk drop on my head every time I'm rummaging around.
Here's a picture of the snapped-off piece in question. It looks like my pneumatic arm froze - I can't manipulate it manually unlike the still-operating one.
http://phreque.com/_tempor/DSC02233.JPG
Echostatic is offline   Reply With Quote
Old 04-17-2012, 03:22 PM   #2
Pics? Can't quite visualize what you say has happened.
Old 04-17-2012, 04:54 PM   #3
suckerface
#1 Lemming
suckerface's Avatar
Drives: Light Blue '08 Yaris
Lending a helping hand...
Sorry for the large image, just saved and up'd
Old 04-17-2012, 05:12 PM   #4
Yikes. There's no easy fix for that. First time I've seen it happen. Good luck.
Old 04-17-2012, 05:27 PM   #5
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
Wow that is not good lol
My guess is it looks like it will have to be welded back in.
devinlamothe is offline   Reply With Quote
Old 04-17-2012, 06:11 PM   #6
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
It wouldn't take much to get that welded up...that's pretty crazy that it popped out like that. It won't be pretty, but it won't happen again either.
-Type 07 FFL-
My odometer 03/11
Old 04-17-2012, 07:24 PM   #7
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
Just watch when you decide to get it welded might have to remove rear glass to prevent it getting shattered
or you could just carry a broomstick to keep rear up n open
OTA'sTOY is offline   Reply With Quote
Old 04-18-2012, 08:27 AM   #8
Echostatic
Glad I could blaze a trail with a new failure :) Thanks for the suggestions, all. Looks like I'll be keeping the parts handy and going for a weld when the droopy liftgate gets on my nerves!
Old 05-18-2012, 10:34 AM   #9
Echostatic
Solved. I bought these (just in the nick of time, looks like. Currently unavailable): http://www.amazon.com/gp/product/B00...ls_o00_s00_i00
...and a local body shop charged $100 to re-weld the detached piece and slap on the new trunk struts. All said and done, $154 and it's back to working like new. Not as terrible as it could've been!
Old 05-18-2012, 04:00 PM   #10
RedRide
RedRide's Avatar
There is a great vendor that has been around for many years that sells qualty lift supports for most any vehicle.......... " "lifttsupportsdepot.com"
http://www.autopartsbylou.com/index.php
People who have ordered from them say the quality is first rate and, the prices are low. They also sell all kinds of hardware associated with lift supports.
Here are their supports for the Yaris.
http://www.autopartsbylou.com/lift-s...=mmy&x=18&y=11
Be shure to read the FAQs as it has a lot of info about supports in general that is usefull no matter where you purchase them.
BTW, those type of supports are much stronger than some people realize and there is a lot of stress on the mounts when compressing. It's probably best to always lower a hatch gently when closing.
Old 05-18-2012, 04:09 PM   #11
poorsh2
Drives: 2008 yaris hb
Use a big molly bolt to hold the bracket. That is ugly
good luck
poorsh2 is offline   Reply With Quote
Old 01-03-2015, 09:17 PM   #12
vandallen
vandallen's Avatar
Drives: 2007 Yaris Hatchback
This happened today 1-03-2015 to my wife's Yaris. The left side broke completely off and the right side broke one weld. I drilled holes away from the broken part and put sheet metal screws in it.
We will see what happens.
Van
vandallen is offline   Reply With Quote
Old 09-11-2017, 10:54 AM   #13
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Add me to the list of casualties for this failure mode. I'll probably just use JB weld after removing a little bit of paint to get good adhesion. What a pain in the arse!
Old 01-01-2019, 02:05 PM   #14
jazzyb88
Drives: 2009 Hatchback
My left side (second one now!) just went today - happy new year to me
First one snapped in July of 2016 and at the time I took it to a body shop for repair. What they did was drill through two holes on the bracket and then drill another two holes in the boot lid so they could then secure the bracket using 2x M6 hex nut and bolts.
I might attempt the same repair myself but the only thing I'm unsure about is how to tighten the nuts on the inside?
Or perhaps I just give them the repeat business lol
In hindsight, it might have been cheaper just to get a whole new hatchback from the breakers!
jazzyb88 is offline   Reply With Quote
Old 01-01-2019, 03:09 PM   #15
komichal
I guess this can be fixed easily with rivets.
I hate rivets... but from time to time they do make one's life easier.
Old 01-02-2019, 02:31 AM   #16
jazzyb88
Will rivets be strong enough to hold the bracket?
Old 01-02-2019, 06:06 AM   #17
Dodge Aries K
My Yaris is a "racecar"
Drives: 2007 Yaris hatchback
My 2007 did this as well. Friend of mine welded the bracket back on and it's been okay for over a year
-Karl the Uber/Lyft Driver
Dodge Aries K is offline   Reply With Quote
Old 01-02-2019, 08:56 AM   #18
jazzyb88
I'm thinking of going for rivets like these
Just not sure if they'll cope with the force exerted on that mechanism. Guess I can try and if it fails go down the nut and bolt method!
3 Door Hatchback Questions Dorkinheimer General Yaris / Vitz Discussion 12 01-16-2012 05:30 PM
Do any other Toyota front seats have same bolt pattern as Yaris? ScottFern DIY / Maintenance / Service 18 07-02-2007 11:44 AM
Install sedan integrated stereo in hatchback? atebit In Car Entertainment + Electronics (audio / video / alarm) 6 05-22-2007 05:25 PM
Seeking Hatchback owners to help with parts test why_14 General Yaris / Vitz Discussion 2 12-05-2006 11:16 PM
Yaris Hatchback Clearance Height Ryu General Yaris / Vitz Discussion 7 11-28-2006 01:35 AM
