Old 03-12-2007, 06:03 PM   #1
jdubau55
Drives: 2007 White Yaris LB 5 Spd.
Send a message via AIM to jdubau55 Send a message via Yahoo to jdubau55
Somebody steal the motor....
out of this....
http://www.edmunds.com/insideline/do...ticleId=117693
jdubau55 is offline   Reply With Quote
Old 03-12-2007, 06:09 PM   #2
Black Yaris
der Zeck
Black Yaris's Avatar
You know that is just a slightly modified version of the 1.8L they are putting in the Yaris TS. It is already in the Vibe GT/ Matrix
Old 03-12-2007, 08:23 PM   #3
Dragonacc
Drives: 07 Yaris LB, 70 Mach 1, 84 5.0
The Elise and Exige use the 2zz-ge, the Yaris TS is not using that engine. It may be a 1zz-ge (I'm not sure) but the 2zz and 1zz are much different animals.
EDIT: I actually think the new 1.8 will be a modified 1nz, but who knows.
Dragonacc is offline   Reply With Quote
Old 03-12-2007, 08:38 PM   #4
forpinks
forpinks's Avatar
Drives: 03 Toyota Corolla S modded,
The engine they used for the Scion xD and Yaris TS is the 2ZR-FE "ported/modified 1NZ block" dual VVT-i, its more high-tech than than the 2ZZ-GE with VVTL-i but with less power because it doesn't provide intake valve lift but, it does also control the exhaust valve timing... just like the IS-350 with a smaller displacement.
I hope this enlightens you...
They have plans on making a Dual VVTL-i for the upcoming 2010 "KING" Supra!
forpinks is offline   Reply With Quote
Old 03-12-2007, 08:44 PM   #5
Dragonacc
Thanks for the info on the new engine, but I wouldn't call it more advanced than the 2zz, variable valve lift is a big deal for performance.
As far as a new Supra is concerned... I believe it when I see one sitting in a Toyota dealership.
EDIT: Also note the engine name, uses FE at the end designating an economy engine rather than a performance engine.
Old 03-12-2007, 09:20 PM   #6
jdubau55
I think I'd rather just have the Exige. It would be a nasty swap though.
Old 03-12-2007, 09:27 PM   #7
Dragonacc
No doubt, so would I.
Old 03-12-2007, 10:26 PM   #8
The 1.8 of the Yaris TS is a new block, the 2ZR-FE, successor to the 1ZZ
Old 03-13-2007, 02:02 PM   #9
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
the yaris got the matrix base engine...vvt-1 140 hp.. not the vvtl-i from xrs...by the way this wll be reuse for the new toyota blade!!
Old 03-13-2007, 02:12 PM   #10
Black Yaris
der Zeck
http://www.toyota.co.jp/en/news/06/0613.html
Old 03-13-2007, 04:32 PM   #11
jdubau55
still doesnt even break 140hp
A/c blower motor noise!!!! LBdriver General Yaris / Vitz Discussion 28 09-12-2007 07:46 AM
Exchanging Motor on a Liftback 1.3 Lt weckjuan Performance Modifications 8 11-12-2006 10:58 AM
Yaris T-Sport showing at British Int'l Motor Show VitzBoy General Yaris / Vitz Discussion 3 07-22-2006 12:01 AM
Motor Silk jcove DIY / Maintenance / Service 3 04-09-2006 07:54 AM
