metallic green vitos
help..check engine again
.....got some trouble issues with my 2002 1.0 auto vitz.....once check engine light is on...mech told me it is the afm sensor...changed..after some trips again change engine light with rough idling.....again mech told me it is the idle control valve......changed this expensive part about 250 euros.....now again!!! rough idling and check engine light is on , but the myth is this....when i start the car i got good idle and good start. no trouble...but after a few drive about 30 minutes the check engine light kicks in. but driving is good condition, but when i stop to idle , it is like shaky u hear like hissing noise under the bonnet. then i turn off the engine, start again....no rough idle no cel, but then again after 30 mins of drive it pops on again.....now i notice a new problem...ac wont kick in since i got this f"$%£ problem....need some help pls i already payed alot of bugs on mechanics and other sh!t...changed....spark plugs, air flow meter, air filter, trassmission oil, engine oil, idle control valve. parts from original toyota dealer. |
Do you know what error codes are being logged now, when the check engine light comes on? With it running fine for a bit and then starting to run rough and throwing the CEL, it may be the O2 sensor.
no logs thats the trouble!! the cel comes on after driving about 30 minutesor more, but as i told you when i shut off the engine and restart it it will go off....not every time it comes on! but when it comes my car on idle its like shaky and ziff ziff ziff noise under bonnet. since no vacuum leak found. are there ways to check the o2 sensor?
#4 | |
#5 | |
Asshole
Drives: 2012 and 2013! Join Date: Aug 2012
Get a scanner, and retrieve the stored code. If there are too many codes stored, erase them. Retrieve the new code as soon as the light comes back.
Cheapest DD I could find!! |
#6 | |
Im sorry I cant help except to recommend to GO SOMEPLACE ELSE!
This is the classic ripoff the consumer with a CEL.
nookandcrannycar please dont be a teacher. im a maltese man that i can speak a little english. if you want to correct people about there language pls find an online job by teaching idiot ppl like me. at other person who replied me , i will get a scanner and let you informed later with codes. thanks :)
#9 | |
back from my mechanik right now...we can get wtf is happing. ok he suggested me to take it to a computer scanner...anyone knows if the code will be store on the ecu? cause sometime the cel is and some time not. or i need to scan it when the cel is on?? thanks
The code should be stored, even if the light is out. You can buy a cheap code scanner to use yourself for under $20 US.
argh sry for misunderstand you mate :) we got evil yaris cars here in malta. not even yaris but glanza and gts....@ ct scott thanks mate.
| check engine code P0101 | bugg_master | Performance Modifications | 6 | 09-24-2016 01:41 PM |
| engine check light | Capsat | DIY / Maintenance / Service | 1 | 06-24-2012 01:03 PM |
| Check Engine "Injector failure Code" | YarisPR | DIY / Maintenance / Service | 14 | 03-04-2007 08:13 PM |
