Awesome!
Drives: 12 Yaris/07 yaris Join Date: Dec 2010
Light Wiring!
alright!
so low beams they have a wider pattern and shorter distance, high beams narrow and long distance. with my old car i wired the fog lights to be on with the switch and lights on, even with high beams. reason is i like the fogs keeping the low wide beams when highs are on, great for highway driving. any ideas on what wires to jump for the relay? thanks! ps 3000k fogs are the best things ever.... |
For the 2012, the fog relay is fully integrated into the body ECU, so to have the fogs always on with the low and high beams you would have to wire them with the headlights in the under-hood portion of the wiring.
You could make them always come on with the lows only, by grounding the wire in pin 3 of the headlight stalk connector, but since the relay and logic are buried inside of the body ECU, you can't easily override the high beam behavior.
Awesome!
that blows..... thanks.
metallic green vitos
better make them on a new curcuit.
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 08:01 PM |
| Need 07 Sedan Tail Light wiring info ASAP | atebit | General Yaris / Vitz Discussion | 3 | 09-07-2013 07:48 PM |
| Fog Light wiring | Rammy | DIY / Maintenance / Service | 0 | 11-08-2012 09:34 PM |
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 02:50 AM |
| LED'n it out (warning...big pics) | custom Lftback | Photo-Video-Media Gallery | 9 | 05-24-2010 04:41 AM |
