HVAC BLOWER ISSUES
Lets just get it out now...... That what she said....
So yesterday i was revamping my audio system, due to a hum from one of my speakers i decided to rewire my entire audio system (Double din HU, 12" Kenwood shallow series sub, 1200Watt mono block amp, 1400Watt 4 channel amp, 8 speakers, 2F Cap) I re-ran all the wires from the HU to the amps and then from the amps to the speakers. i also re-ran the power wires and remote wires. I was very happy with the sound of the system when i was done and the hum is gone. Today when trying to go out i found out that i somehow fudged up my HVAC Electric blower......Actually the entire HVAC control unit seems to be acting up. It no longer lights up when the head lights are one, nor does it turn on the HVAc fan. The AC light will illuminate as long as the selector switch is on any number other then 0 and my rear defogger light will flicker when i press it but will not stay on..... i did check fuse #3 under the drivers side kick pannel and fuse #24 (iirc) in the engine bay and they do look fine. with fuse #3 removed i was no longer able to control the brightness level of the instrument cluster. Also on my HVAC controls, i did check the voltage at the main connector and i did have 12 volts on the red wire any ideas where i may have messed this up? Thanks in advance
| A/C Blower Dismantling? | Yaross | DIY / Maintenance / Service | 9 | 12-14-2011 04:56 AM |
| Why wont my fan blower work? | lucy7509 | DIY / Maintenance / Service | 4 | 08-09-2011 03:48 AM |
| 09 Yaris Heater blower problem | motoxxx3 | DIY / Maintenance / Service | 28 | 10-15-2010 06:45 AM |
| A/C blower resistor | ubear7 | DIY / Maintenance / Service | 1 | 08-08-2010 10:53 PM |
| dead mouse in my blower unit | beacon | DIY / Maintenance / Service | 20 | 11-25-2008 01:31 PM |
