Old 01-03-2013, 03:31 AM   #1
husaynkhan
Drives: new vitz
Badly need help ............
okay , i had a Pioneer DEH-3950mp which was really good........the radio was receiving all the channels without any inconvenience. last month, i decided to buy a new Pioneer which is DEH-5450sd, bought and installed, everything was well, but i haven't checked the radio tuner at the buyer place. At home, the radio was unable to receive any channel, went to the dealer, tried another 5450, then a 8350, then a 2450............BUT all were same. When i shift back to my old DEh-3950mp....all good.
ANY suggestion please..........
husaynkhan is offline   Reply With Quote
Old 01-03-2013, 03:52 AM   #2
husaynkhan
Drives: new vitz
CT scott where are you?
Old 01-03-2013, 04:38 AM   #3
SilverSquash!
Stage ...Base
SilverSquash!'s Avatar
Drives: Toyota Yaris LB '07
Are you using the same harness ie the DEH-3950mp with the newer DEH-5450sd? it could be the problem...also could be the antenna not connected securely... just my opinions
SilverSquash! is offline   Reply With Quote
Old 01-03-2013, 08:01 AM   #4
It is probably the fact that the black wire on the OEM harness is not connected to the "power antenna output" on the new head unit's harness. The Yaris has an RF amplifier built into the antenna base, and if it is not powered the antenna is worthless.
Old 01-03-2013, 05:58 PM   #5
sqcomp
Roadrunner Jr.
sqcomp's Avatar
^X2
CT beat me to that answer
― Thomas Paine
Old 01-05-2013, 03:46 AM   #6
husaynkhan
Drives: new vitz
But i have plug the antenna wire well in the radio, but still nothing. Ct scott try to be a bit more clearer, am unable to understand you.
Old 01-05-2013, 08:17 AM   #7
The antenna also has a separate power wire. It is the black wire on the blue radio connector.
Old 01-05-2013, 12:33 PM   #8
husaynkhan
Drives: new vitz
OKay, so i just found out that in newer Yaris , the antenna already had the power together. So what shall i do?
Old 01-05-2013, 02:59 PM   #9
What year is your Yaris, and did you measure the voltage on the wire to make sure that your headunit is really powering it?
Old 01-06-2013, 01:12 PM   #10
husaynkhan
Drives: new vitz
mine is 2006, i dnt have any equipment to measure.
Old 01-06-2013, 02:57 PM   #11
OK. If you want to try a test, since you don't have a meter, you can take the black wire from the factory blue colored connector and connect it to the grey wire, which is diagonally next to it on the connector.
Old 01-08-2013, 10:51 AM   #12
husaynkhan
Drives: new vitz
So, i bought 1 like this
http://www.best-b2b.com/userimg/658/...ntenna-831.jpg
and install it. By the way i got back to my DEH -3950mp, and by surprise it plays the fm just like the others. In some village it plays well whereas in some it doesn't which was not the case before. So i do't even know what to do?
Old 01-08-2013, 10:55 AM   #13
husaynkhan
Drives: new vitz
And ya the AM too has stopped working
Old 01-08-2013, 02:10 PM   #14
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
@Ctscott. Maybe a picture of the harness and a huge red arrow
Old 01-08-2013, 03:29 PM   #15
One thing I did not think of prior is the tuning spec for both radios. Is the new one rated for your area of the world, as the old one apparently was?
Old 01-19-2013, 12:28 PM   #16
husaynkhan
Drives: new vitz
Finally i had it connected, And it was obviously the BLACK wire. Thanks to CT scott and tohers. :)
Headlight misting (badly) Geoff Peace DIY / Maintenance / Service 9 04-30-2012 11:52 PM
Most popular brands/models for Gen Y - Yaris sedan #4 - American brands fair badly Kal-El General Yaris / Vitz Discussion 2 07-09-2011 08:02 PM
Dwarf singing jonas brothers very badly PETERPOOP Off-topic / Other Cars / Everything else Discussions 2 04-29-2009 08:54 PM
wanted badly!! project_yaris Willing to Buy by private party 1 03-06-2009 09:13 AM
Need help badly looking for engine swap places in gta Adriaan Canada 7 02-23-2009 09:14 PM
