Old 05-03-2009, 10:42 PM   #1
fuji
fuji's Avatar
Drives: Polar White Yaris HB
My Tein Coilovers go "Bang!"
I could you some help from you guys....Just got some Tein coilovers installed and the handling is fantastic! The only problem so far is every time I go over some rough road, I hear a very loud "bang"! It is coming from both left rear and right rear. There is no tire rubbing. Everything looks like it is installed properly. Any thoughts on what may be causing this????
Thanks in advance
fuji is offline   Reply With Quote
Old 05-03-2009, 10:43 PM   #2
ChinoCharles
Drives: LB
Sounds like your struts are bottoming out. Dampening isn't set right?
Old 05-28-2009, 11:14 AM   #3
m911gt
Carless in Chicago
m911gt's Avatar
Drives: 08 Blk LB
Anybody please, are the Tein Basics equipped with adjustable dampening?
Wanted: Forced Induction
Old 05-29-2009, 02:03 AM   #4
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
hey bro , no the basics have a set damping , cant adjust , you will need the super compacts from japan like i got , the got 16 way damping / rebound adjustment
JDMtuner
Import Performance Tuning
www.jdmtuner.co.za
Old 05-03-2009, 11:32 PM   #5
sounds like youre hitting the bumpstops....how low are you?
Old 05-03-2009, 11:53 PM   #6
supmet
Drives: 2007 4 Door Yaris
sounds like one of the old batman shows... BANG! POW! ZAP!
Old 05-04-2009, 12:11 AM   #7
gwasabi
Drives: 07 Blazing Blue LB
Same thing happening to me on DF210 just ignore em runemhard!. lol or grab a set of tokico blues!
Most Satisfying Crew
Serious Business...
MunkyWurks Garage - 8088488794
gwasabi is offline   Reply With Quote
Old 05-04-2009, 02:13 AM   #8
fuji
fuji's Avatar
Hmmmm. Bump stops. Are they supposed to be trimmed prior to installation of coilovers set low?????
Old 05-04-2009, 04:03 AM   #9
Sabretooth
37HSSV
Sabretooth's Avatar
Drives: '11 Mazdaspeed 3
How low do you have the coilovers set for height wise, sounds like your not giving them enough room to move with the motion of the car, you might have them too low, thus they just give a bit and hit bottom. If you have them lowered heavily, I would suggest trying to raise them, I have had mine for almost 6 months now, with no issues with bottoming out, but I also have mine setup or a moderate drop, I could dump them if I wanted to. Risking the same effect as you are describing.
Old 05-04-2009, 04:12 AM   #10
fuji
fuji's Avatar
When I got them installed, the install shop set them at almost max lowering. It looks like about 2 inches. Let's just say he fenders are covering the tops of my 195/55/15s.
Old 05-04-2009, 04:15 AM   #11
fuji
fuji's Avatar
I definately need to raise the rear end. I may also consider cutting an inch off the bump stops in the rear given the loud "whack" occurs with not too mcuh force.
Old 05-04-2009, 11:52 AM   #12
MUSKOKA800
MUSKOKA800's Avatar
Magazine car ride height (fantasy) vs. streetable ride height (reality).
Two very different specifications (unfortunitely).
Old 05-04-2009, 04:11 PM   #13
fuji
fuji's Avatar
Exactly where are the bumstops located, I will have to crawl under the car and take a look
Old 05-04-2009, 04:29 PM   #14
Russelt3hPirate
l33t3st Asshole
Russelt3hPirate's Avatar
Drives: MY07 Yaris Liftback
first check to make sure the bolts are tight up top and that the lower bolts are tight as well.
the bump stop is in or on the strut so you'll need to uninstall them, and you shouldn't need to modify them from Tein, you just need to raise the car.
Russelt3hPirate is offline   Reply With Quote
Old 05-04-2009, 04:58 AM   #15
bumpstops shouldnt be oem, tein will have their own in the coilover kit...
it sounds to me you have to raise the rear end a bit....especially if youre tucked....have a pic?
Old 05-04-2009, 11:04 AM   #16
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
Adjust the Teins until you have about 1 1/2-2 inches between the tire and fender ( all 4 wheels ) or, you can use the measurements provided by Tein in the instructions .
Old 05-04-2009, 07:09 PM   #17
bumpstops on my megan coilovers are under the dust cover....
Old 05-05-2009, 05:54 AM   #18
fuji
fuji's Avatar
Well I checked the bump stops and the overall install. Everything appears to be correct. I even adjusted the rear coilovers higher. Still have the "whack" sound alternating from both sides. It sounds like someone is hitting the plastic panels with an antenna or something. Any other thoughts? This has had to have happened to someone else!
Yaris TS lowered on Tein Basics Coilovers CASTREX Yaris TS Talk 9 08-17-2009 12:34 AM
TEIN - Basic Coilovers *Now Available* EnduroMTS Sponsors Classifieds Area 4 10-13-2006 02:43 PM
TEIN Basic coilovers C2AUTOSPL Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 06-26-2006 01:57 AM
