Old 01-24-2013, 04:08 PM   #1
grchristoff
Drives: 2007 yaris
Heater Problems
Hi, I have a 2007 yaris and when I turn on the heater I can hear the motor running, but I get little to no air coming out of the floor vents or the defroster (regardless of the knob settings). Its almost like the flapper in the heating vents is closed.
Does anyone know the best way to access the heater box on these cars? Do I need to take out the glove box door?
If anyone has suggestions or a diagram of how the heater box works I would appreciate it.
thanks
grchristoff is offline   Reply With Quote
Old 01-24-2013, 05:23 PM   #2
You can grab the AC section of the service manual from the Micro Image forum to see how the flappers work. It is likely that the cable that changes the output position popped off of the back of the knob (pulling off the vertical black pieces and then pulling off the control panel gives you access). The other end is accessible behind the glove box.
http://www.microimageonline.com/foru...32-YARIS-FILES
follow up on 2010 yaris problems + more problems heavenswaitin DIY / Maintenance / Service 18 09-03-2013 04:47 PM
A few problems drunkwithwords General Yaris / Vitz Discussion 1 04-01-2010 12:13 PM
My $7 Interior Upgrade - Center Heater Vents Meteorite_Marty Cosmetic Modifications (Exterior/Interior) 54 05-18-2009 09:51 AM
Rostra seat heater and lumbar support sesmith In Car Entertainment + Electronics (audio / video / alarm) 1 01-03-2009 09:51 AM
