Old 10-19-2006, 05:15 PM   #1
barryware
Valve Noise
I have had my Yaris for about 6 weeks. I just noticed that after the engine is warmed up, there is a "ticking" noise from the engine. It is typical of when an engine is in need a valve adjustment. However, a new engine shouldn't need a valve adjustment. In doing a little research, these are not the typical type of valves to adjust. You have to measure your clearance, do a little math, and replace the lifters with ones of differant size.. Boy!!.
So... Am I being to critical of the engine / valve train noise? When the engine is started and cold, it is a quiet as can be. Once warmed up, the valves are ticking.
I have owned several 4 cylinder powered cars and none have ticked.
Someone said that it may be the fuel injectors I am hearing. This would not explain why when the engine is cold that the sound is not there.
I guess I should bring it in but warranty or not, taking in a car is a pain in the a$$.
Anyone else have a ticking engine?
barryware is offline   Reply With Quote
noise while backing up jonr0613 General Yaris / Vitz Discussion 31 09-08-2007 07:23 AM
Clicking noise in center console? devinlamothe General Yaris / Vitz Discussion 8 09-16-2006 12:03 PM
Loud scratching noise dngz General Yaris / Vitz Discussion 3 09-11-2006 11:56 PM
engine noise?? poshi General Yaris / Vitz Discussion 23 09-04-2006 11:45 PM
Noise in the A/C System cburac DIY / Maintenance / Service 1 05-16-2006 07:14 AM
