Old 01-29-2013, 11:50 PM   #1
Yarflana
Drives: 2008 Base Model
Shocks upgrade
Want to upgrade the rear shocks from stock. I looked a for while on the forum and found really only the Monroe Sensa Trac and Tokico shocks being used.
If I am looking to install a rear sway bar at the same time as upgrading the rear shocks, what do you suggest for the shocks?
Please advise...thanks,
Pat
Yarflana is offline   Reply With Quote
Old 01-30-2013, 10:04 AM   #2
DeathBeard
DeathBeard's Avatar
Drives: 2010 Yaris S
Tokico,Monroe is a inferior product
"In his heart a man plans his course, but the Lord determines his steps."
Proverbs 16:9
DeathBeard is offline   Reply With Quote
Old 01-30-2013, 11:10 AM   #3
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
There is also kyb
http://shop.microimageonline.com/KYB...et-KYB-GR2.htm
Old 01-30-2013, 11:32 AM   #4
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
If you wait a bit, megan is supposed to be releasing some stock replacement shocks, I tested them and was very surprised on how well they performed. Otherwise I'd say find a set of rear HTS's or blues.
Old 01-30-2013, 11:42 AM   #5
Yarflana
So these KYB will work?
So these would work for the rear?
I only want to do the rear at this time.
http://www.amazon.com/KYB-343442-GR-...1&s=automotive
Old 01-31-2013, 01:09 AM   #6
This should be moved to the wheels and suspension section.
OP, I'd suggest doing all four at the same time. I installed my TRD struts up front, and left the rear OEM since we couldn't figure out how to get to the top rear shock nut at the time, and man, my car handled pretty bad. Once the rear TRD shocks were on, my car handled so much better.
Old 01-31-2013, 11:10 AM   #7
Yarflana
Thanks Koatic.
I plan to do the rear first since there is less action back there, and a sway bar. I will get to the front shortly thereafter, but retain the stock springs.
Old 01-31-2013, 02:13 PM   #8
I'll price match on the rears, but the GR2 is not much of an upgrade in terms of performance (meaning you won't feel much difference). If you want a performance shock, you'd want Tokico blues. I can sell just rear pairs.
Old 01-31-2013, 03:55 PM   #9
Megan has no concrete plans to release the product anytime soon. Certainly not before the beginning of 2014. Further, this product will be intended as an OEM replacement, with no difference in damping and no adjustment.
I'm not sure what you thought you were feeling with them, but there should be no actual performance improvement with this product.
Old 01-31-2013, 05:44 PM   #10
Absolutely Red 12
Asshole
Absolutely Red 12's Avatar
Drives: 2012 and 2013!
Buy all 4 Tokicos and the rear sway bar at once from Garm at Micro Image!!
Garm, make him a deal!!
Cheapest DD I could find!!
Absolutely Red 12 is offline   Reply With Quote
Old 01-31-2013, 05:58 PM   #11
UberSilver
UberSilver's Avatar
How much Garm? I've been looking for new shocks as well.
Can you get anywhere near $300. for all four corners?
Old 02-18-2013, 09:31 PM   #12
vadr45
vadr45
vadr45's Avatar
Drives: 2009 Base 3-door
Gotta tell ya - I did the front and rear TRD shocks together and the car handles beautifully now. Previous owner only put in the TRD rear sway bar and lowering springs and it wurnt enuf. Even Madame appreciates the better ride profile.
vadr45
Alexandria, VA
2009 Black Base 3-Door Yaris
1950 Austin A70 Hampshire
vadr45 is offline   Reply With Quote
Old 02-18-2013, 10:39 PM   #13
Yarflana
Yeah, already put on Eibach's and Tokico reds and TRD sway. Much better now...an then some. Just trying to decide now whether the Eibach's get me low enough.
Old 02-18-2013, 10:46 PM   #14
Nice.
Old 02-18-2013, 10:47 PM   #15
How long ago did you install the springs? If it wasn't too long ago, then they'll still settle and drop a little bit more. However, Eibach's drop is, what, 1.1" or 1.5"? I forget.
Tein S-tech Springs with Stock shocks combination. daddz07 California 11 08-21-2010 02:49 PM
Tein S-tech over Stock shocks daddz07 General Yaris / Vitz Discussion 0 08-10-2010 11:48 AM
Tein S-tech Springs with Stock shocks combination. daddz07 Performance Modifications 1 08-09-2010 04:45 PM
front shocks independent from rear shocks? ammophobia Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 02-05-2010 12:34 AM
Shocks upgrade??? CASTREX Performance Modifications 24 01-29-2007 02:13 PM
