Old 02-19-2013, 03:20 PM   #1
ochy38
Drives: '08 Yaris 3 door
Cupping on interior shoulders of rear tires
Hi everyone, my GF has been putting a lot of highway miles on her '07 yaris 3 door recently, and I noticed a lot of road noise from the rear of the car. Got down and looked today and the tires are beginning to cup quite a bit on both rear's on the inside walls. I did a quick check on the fronts, they looked fine but I should look again. What could be the problem here? The car has about 120Kmi on it.
ochy38 is offline   Reply With Quote
Old 02-19-2013, 06:06 PM   #2
TOUGEghost
Mr. Clean
TOUGEghost's Avatar
Drives: 2009 Yaris S 3-Door
Lack of tire rotation.
Old 02-19-2013, 08:24 PM   #3
UberSilver
UberSilver's Avatar
Drives: 08Yaris2D, 88LandCruiser.
Shot shocks., bad bearings(less likely).
UberSilver is offline   Reply With Quote
Old 02-19-2013, 10:04 PM   #4
ochy38
I pushed on the car and it didn't keep bouncing, but I suppose with 120K the shocks are about due. It doesn't sound to me like the bearings are going on the car, kind of noisy but I relate that more to the cupping of the tires.
Old 02-19-2013, 11:12 PM   #5
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
X2
Old 02-20-2013, 12:54 AM   #6
CoryM
Drives: 2009 5-door, 5-speed
If it is just the inside edges that are wearing, it's probably toe wear. Blown rear shocks will make for cupping across the entire tread, worse in the middle.
What tire are they? Some tires are very prone to cupping/noise just by design.
Old 02-20-2013, 09:41 AM   #7
ochy38
The tires are plane jane Bridgestone Insignias. I didn't think there was a rear toe adjustment on this car.. is there a bushing or something that could cause the toe to go out of spec? Seems to be happening pretty evenly on both tires. I'll take a closer look after work today but memory tells me that the wear starts at about center of the tire and gets worse the closer you get to the inside shoulder
What would cause this? Wheel bearing? something else?
Old 02-20-2013, 10:03 AM   #8
TOUGEghost
Mr. Clean
TOUGEghost's Avatar
Rotation as in removing the wheels and tires and rotating them to a different position on the vehicle. This is done to prevent uneven tread wear and prolong the life of the tires.
Old 02-20-2013, 10:32 AM   #9
ochy38
Ah, understood. She is definately overdue for a rotation, but (and maybe I'm wrong) I would assume cupping would point to a suspension issue, I was under the impression that rotating just allowed all four tires to wear evenly in relation to eachother.
Old 02-20-2013, 02:29 PM   #10
ochy38
I just looked into the rotation issue some more. Definately thinking thats the problem, its been at least 1.5 years since she rotated the tires. I've been a amateur-ly working on cars for the last 5-6 years and never heard about that one. I just assumed rotating allowed all four tires to wear evenly in relation to each other. Thanks for the info.
Old 02-20-2013, 09:56 PM   #11
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
just do some research before rotating them anything but front to back. Nowadays even a lot of cheap tires will almost disintegrate if you try to put them on the other side of the car. Something about handling characteristics making it not possible or something like that.
Colin Chapman disciple
Old 02-20-2013, 11:40 PM   #12
CoryM
The rear suspension of the Yaris should make for flat tire wear. You should not see any cupping from the rear at all. The idea is to take the tires from the front of the car (where they get worked hard doing steering and camber changes) and put them on the rear so they can become smooth again. Chances are you have some toe-in on the rear axle (from pothole or curb bump most likely). It is possible that it is from lack of rotation, but it is unlikely IMO. I would suggest getting your alignment checked. Do a google image search for "toe wear" and compare to what you have.
Cheers.
Old 02-23-2013, 01:36 AM   #13
Viperoni
Drives: 2005 Toyota Echo
The cause of cupping can be a tough one to determine, but i'd go with worn shocks and negative camber, or negative camber and toe in.
2006 Saturn Ion Redline
2005 Toyota Echo RS 4dr hatch - Cyl #3 bad - sold
2000 Toyota Echo 2dr coupe - The track car - rusty & scrapped
Viperoni is offline   Reply With Quote
tire noob question..what's the widest tire size can run on stock 15"s? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 12-06-2011 10:44 AM
Newly installed 15" tires feel 'weird' kristan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 04-24-2010 07:58 PM
