Old 06-27-2013, 05:49 AM   #1
peewee1
PEEWEE1
peewee1's Avatar
Drives: 2009 yaris s sedan
gas pedal improvement
Is there any way to improve the gas pedal on a 2009 sedan s, automatic tranny. Do the add on pedal covers really work? My gas foot almost cramps up from applying light pressure on the pedal, or my foot remains at such a different angle so as to make that crampy feeling. Any ideas??
peewee1 is offline   Reply With Quote
Old 07-02-2013, 12:40 PM   #2
Amdkt7
Returning to Toyota
Drives: 2013 L 3dr MT
In my Kia, I needed a pillow to support my leg, but not needed in the Yaris.
Amdkt7 is offline   Reply With Quote
Old 07-02-2013, 01:13 PM   #3
YarisSedan
Drives: 08 Yaris Sedan
Are you a tall person there is a diy mod for more seat thighssupport so there is less pressure on your foot it pretty much consists of spacers to elevate the front of the seat a bit
Old 07-02-2013, 02:41 PM   #4
Amdkt7
Returning to Toyota
Hum, where can you buy spacers? I was looking for offset plates, but spacers would be easier, and should help, at least a little.
Old 07-02-2013, 04:50 PM   #5
DMZ
DMZ's Avatar
Drives: 2007 Yaris LB
Drive barefoot. Use your toes.
2007 LB W/Cold Wx Package
DMZ is offline   Reply With Quote
Old 07-04-2013, 02:15 AM   #6
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
I drive barefoot all the time.
It's very comfortable.
Old 07-02-2013, 04:59 PM   #7
Amdkt7
Returning to Toyota
wonderful idea DMZ.... especially in cold weather! Actually, I remember my feet getting hot from the firewall in an older car...
Old 07-02-2013, 05:09 PM   #8
DMZ
DMZ's Avatar
Anytime I am going long distance I will drive either barefoot, or stocking footed. It keeps my leg from cramping because I can hold the pedal at different leg positions depending upon which toes I am using.
It also gives me a much better feel for the throttle and brake.
I had a 57 Chevy truck that would radiate a great deal of heat through the firewall and floorboard. Some vehicles back then had a vent door near the floor, that you could manually open, to keep the heat vented away a bit.
Old 07-02-2013, 05:18 PM   #9
Amdkt7
Returning to Toyota
Mostly, my feet are cold, and I want more heat on them!
Old 07-03-2013, 08:47 PM   #10
TLyttle
TLyttle's Avatar
Drives: 07 Yaris sedan
Ever since I got my Yaris, I have complained about the throttle being too light, and that it needs a heavier spring. Then I was told that there is no spring, that the pedal is simply counterweighted, and that I would get used to it. Well here I am, 6 years later, and the light throttle is still the only thing I really dislike about this car!
Old 07-03-2013, 09:53 PM   #11
Jason@SportsCar
Not true... I just took one apart last night, there are a pair of coil springs inside, one inside another.
Not my images, but you can see the springs:
Old 07-03-2013, 11:27 PM   #12
TLyttle
TLyttle's Avatar
Ha. I stand erected. So, I take the thing apart and look for valve springs out of a Buick or somesuch source, or install a linear screen door spring. Either way, I will have to install non-Toyota parts to get rid of the constant shinsplint I get driving the car as it is...
Old 07-04-2013, 12:24 AM   #13
Kar98
Drives: 2011 Scion tC
Install cruise control?
Kar98 is offline   Reply With Quote
Old 07-07-2013, 02:30 PM   #14
schume
Drives: 2010 Yaris LB
That's the reason I installed cruise control on mine! After a two hour drive, the top of my foot and shin would be in a lot of pain. Around town doesn't bother me, but freeway driving, engage cruise asap! :)
schume is offline   Reply With Quote
Old 07-04-2013, 12:45 PM   #15
TLyttle
TLyttle's Avatar
Driving barefoot (or with sandals or flipflops) is against the law here, $130 fine, not that it is enforced very often. They usually add it on after an accident. Besides, this is the North, and barefoot is only possble for a few weeks a year!
Old 07-04-2013, 01:15 PM   #16
tooter
play every day
tooter's Avatar
It's nice that no one can see my feet while I'm driving because I do it all year round.
Old 07-04-2013, 01:09 PM   #17
RedRide
RedRide's Avatar
In any event, the gas pedal resistance on the Yaris is too light when the geometry of access is considered. One is forced to almost stand on it instead of pressing it latterly which puts a strain on your foot and leg as you struggle to hold them in the required position. You are not only pressing the pedal but trying not to press it too hard at the same time.
Yes, you can get used to it for the most part but, if the seat was lower. etc or the spring was stronger, it would be more comfortable.
BTW, the fact that there is one spring inside the other suggests to me that someone was aware of the design problem and one more spring was added. However, it is still not enough IMO.
One can not make the spring as situated too strong in the plastic components ....a design flaw?
With a traditional cable throttle, the spring tension can be tailored for an individual car model at the throttle body by adjusting the spring size and geometry of the cable attachment at the pedal as well as at the throttle body.
Old 07-08-2013, 01:45 PM   #18
Jason@SportsCar
Wow is that ever a ridiculous reach. The fact that there is a spring within a spring simply offers the engineers an avenue for creating a progressive rate pedal - two different size springs of different sizes and rates that engage at different points in the travel offers a lot of tuning options. Changing the internal spring and ECU throttle mapping makes it possible to use the same assembly in a different model car that utilizes a different level of "perceived" performance.
Lexus IS250 gas pedal + Lexus IS Sport Pedals/deadpedal Gideon Cosmetic Modifications (Exterior/Interior) 15 10-04-2022 03:50 AM
GAS PEDAL SPRING TOO WEAK DANIELTNIEVES General Yaris / Vitz Discussion 21 10-06-2016 12:41 PM
Gas pedal not engaging/accelerating tzchaiboy DIY / Maintenance / Service 0 08-30-2012 10:30 AM
Natural Gas Transportation - Why Not? Kal-El Off-topic / Other Cars / Everything else Discussions 1 03-20-2011 02:12 PM
Free gas for any vehicle. ketel0ne General Yaris / Vitz Discussion 4 09-19-2006 09:07 AM
