Old 09-21-2011, 12:53 AM   #1
NickNickNick
Drives: 06 Silver Yaris 3-door Manual
Grinding noise in reverse
So, after replacing the engine and clutch in my 2006 Yaris, it's been driving just swimmingly for the past 6 weeks.
But, today, I noticed a strange noise (a lower-sounding grinding) when I put the car in reverse. Obviously, it's a manual transmission. Like I said, I just had the clutch replaced about 6-7 weeks ago. The grinding doesn't shake the whole car or anything, it's just a brief low rumble that can be heard about 60% of the time when I start into reverse (ie, when I begin to idle the engine higher and as I start to let the clutch out). It almost sounds the same as when you get a little packed snow or ice into the undercarriage. I have included a link to a video where the sound can be heard. It's the low grinding just when I start to move backwards.
It also doesn't seem to happen all the time - if I let the clutch out really slowly, it makes no sound. If I just give it a little gas and shift to neutral right away, it makes no sound. Only seems to make a sound when I let the clutch out completely - and even then not all the time.
Anyone know what this new problem could be?
Thanks.
Here's the video:
http://www.youtube.com/watch?v=xqhlglTIZoU
NickNickNick is offline   Reply With Quote
Werid Noise When I throw it into Reverse LoudYar General Yaris / Vitz Discussion 12 10-26-2020 05:57 AM
Rattle - Noise when Yaris put in Reverse Jungle Rot DIY / Maintenance / Service 14 08-27-2015 07:32 AM
Help With Reverse Noise???? JoshW DIY / Maintenance / Service 0 09-09-2011 01:27 PM
ABS?, Grinding Noise When Brakes Are Locked!??? p0pNfr3sh DIY / Maintenance / Service 3 03-03-2010 06:22 AM
2007 LB Auto-Trans NOISE in Reverse Pavel Olavich General Yaris / Vitz Discussion 4 03-22-2007 08:42 PM
