Old 03-31-2013, 12:55 PM   #1
Melloreel
Drives: 08 3dr LB
Cruise Install, Thanks to CTScott
I just wanted to pass along my experince with buying, and installing the cruise kit from CT.
I had a couple of questions I needed answered while installing the kit! I had the car torn apart, and had to get it back together same day.
I took a chance and sent a pm to scott figuring that it would a day or two before he responded? To my surprise, it only took minutes! Thats what I call support!!
Everything worked great, and it was the best addition I've made so far
Melloreel
Melloreel is offline   Reply With Quote
Old 03-31-2013, 05:36 PM   #2
MyzticZ3r0
Drives: 2007 Toyota Yaris Hatchback
Melloreel
Congratulations Melloreel! I was contemplating about installing it myself, but I'm too chicken to mess with the steering wheel.
MyzticZ3r0 is offline   Reply With Quote
Old 03-31-2013, 05:39 PM   #3
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
CT is an awesome guy. i did the same install last summer with the same results. the DIY he sent me was exhaustive and covered literally everything.
The parts were cheap and install straight forward. the functionality.... perfect.
Be the change you wish to see in the world -Mahatma Gandhi-
BEEF is offline   Reply With Quote
Old 03-31-2013, 09:43 PM   #4
Melloreel
Drives: 08 3dr LB
To me that was probably the easiest part! The only problem was the indicator light location in the instrument cluster! I looked at two different instructions on its location, and got confused? CT sent me pics that clarified the location!
Just a thought CT maybe your DIY could show the pics that you sent to me?
Also I broke the cover that goes over the connector to the ECM. No big deal as I just wire tied it back on. It took a good bit of twisting the screw driver as suggested to release the tabs. It broke the two hook tabs at the back. Be very careful!!
Old 04-01-2013, 12:13 AM   #5
mf4361
Drives: Yaris Sedan
I chickened out on taking the steering wheel apart too, that's why I took the resistor/momentary buttons approach. Functions exactly the same way.
mf4361 is offline   Reply With Quote
Old 04-01-2013, 09:41 AM   #6
BEEF
BEEF's Avatar
The button approach is interesting but it doesn't look factory.
I wonder if I should have put the indicator light on mine but I just don't have a good place to mount it as my 2008 doesn't have a factory location for it. I wanted mine to keep the factory look (somewhat).
I guess it is what you are used to as my other car has cruise on a stalk as well.
Old 04-01-2013, 05:20 PM   #7
mf4361
Drives: Yaris Sedan
That's true too. I put the buttons on the power mirror cover on my 07' so Its not quite visible from other seats in the car. Plus I can always replace it with a new cover and it'll look OEM again.
Old 04-01-2013, 05:54 PM   #8
Melloreel
Drives: 08 3dr LB
That was my point Beef. The indicator can go right next to the clock! To me it was a must have. Being anal as I am I would always be checking the switch it's very close to the edge of cluster, but still looks like factory installed.
Now take a day and install the kit, and you will be as happy as I am with the results
Old 04-01-2013, 08:44 PM   #9
Here are the pictures I emailed to Melloreel to show how to mount the indicator within the cluster. It may not be 100% OEM looking, but once the cover is back on the cluster is looks very good.
Old 04-02-2013, 10:51 PM   #10
nickhjort
My R1 eats my Vitz!!
nickhjort's Avatar
Drives: '07 Vitz Lifty, Stick Shift
Man I haven't been on here forever!
But I had to comment here because this looks pretty familiar :) Although mine is flickering on and off now when I use it. Either a loose wire or the box you made me going bad, I'm not sure which. I have to take the dash apart one day and find out.
My Car Rules!
nickhjort is offline   Reply With Quote
Old 04-02-2013, 10:53 PM   #11
nickhjort
nickhjort's Avatar
And the light turning on and off :) Ignore the crappy fake leather job around the radio, it has since been removed.
My Car Rules!
Old 04-03-2013, 12:06 AM   #12
BEEF
BEEF's Avatar
too many other projects for me right now. I may eventually do it. I gotta put on my MI pulley first and get some things done around the house (just bought a house in february). amazing how our time gets allocated out.
DIY Cruise Control FAQ (2006-2010 Yaris) CTScott DIY / Maintenance / Service 468 11-19-2024 04:45 PM
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 10:22 AM
Compilation of Yaris How-tos/DIYs YarisBueller DIY / Maintenance / Service 39 04-28-2018 09:47 AM
Rostra cruise control install kimbhoot DIY / Maintenance / Service 1 09-02-2011 12:34 PM
Dealers are refusing to install cruise control xenu General Yaris / Vitz Discussion 12 07-17-2010 01:49 AM
