![]() Drives: 2010 Black Yaris Lb Join Date: Apr 2010
Whiteline Polyurethane Bushing Review
Hey guys, just wanted to tell everyone about a great upgrade for handling!
I installed Whiteline synthetic elastomer control arm bushings and I have to say wow! The car feels much more planted through turns, especially mid-corner. It also seems it reduced a good amount of under-steer during initial throttle application, I am not sure if that is because of a reduction in front end compliance though. Be aware that you will have issues installing these if you have a sub-frame brace, due to these bushings being much less compliant; also always perform an alignment after any suspension work. Bumps are a little more noticeable, but not bad. All in all a very good modification. Supporting mods. TRD suspension kit TRD rear sway bar GTSPEC front, mid, rear chassis bracing Ultra racing front strut brace Team dynamics 15x6.5" et +38mm Monza R wheels 195/55/15 Hankook Ventus v2 tires |
Great product, and in stock.
How do you like your tires I am looking to buy the same ones and size in a few weeks. I been looking to do these bushings I notice my caster is off last time I did my alignment so if I'm going to replace worn put using might as well upgrade them at the same time
I do have Whiteline control arm bushings ... and my only problem is when I drop in a pothole and bump (you get to believe by the sound that you damaged your car (with the time you get use to it). Beside that they are wonderful.
LOl probally one of the main reasons oem is rubber.
| bushing came off metal sleeve on rearstrut? tein coilover | TRD.RiC | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 03-18-2012 10:14 PM |
| alternator bushing JAMMED ! | Siffleu | DIY / Maintenance / Service | 12 | 10-22-2010 10:12 AM |
| Polyurethane? Bushing Kits? | bronzebullet232 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 17 | 06-18-2010 03:45 PM |
| Review of the 2009 5-door and 3-door Yaris Liftbacks | csburdick | General Yaris / Vitz Discussion | 14 | 01-03-2009 07:09 PM |
