Old 11-05-2010, 01:35 AM   #1
Idahotom
Drives: 2008 5 sp. LB
Low drag mirrors
Am I the only one to fold the side mirrors back? I'm talking middle of Wyoming, and into a 30 mph headwind. I was always in the right hand lane, (interstate) traffic was very light, like none. My neck still can turn, and I have a rear view mirror. As I neared a town, I'd flip them back out. Safe enough, probably not legal. I havn't done it since, just that long stretch with the headwind and it was getting real boring. Can't say I could see a difference on the scangauge, and I only did it for a couple hundred miles.
Idahotom is offline   Reply With Quote
Old 11-07-2010, 08:22 PM   #2
MUSKOKA800
MUSKOKA800's Avatar
I'd rather have full visibility than be obsessed over the drag, if any, they add.
I'd think the envelope that the front of the car creates going through the air at highway speeds extends out past the side mirrors. If it didn't, wouldn't the manufacturers see this in the wind tunnel and tune the mirror size/shape accordingly???
Old 11-07-2010, 09:20 PM   #3
Klink10
Klink10's Avatar
Tune the size accordingly? You would think but then they can't even come up with a quality waterpump.
Old 01-07-2011, 11:46 AM   #4
Toyota_Yaris
Drives: 2007 Black Yaris
hahahahaha x's 2
62k miles on mine and I just went through my first waterpump
Toyota_Yaris is offline   Reply With Quote
Old 11-07-2010, 09:56 PM   #5
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
actually mirrors are tuned for visibility first, and drag is accepted in that area.
You can buy racing style mirrors if you'd like, they are much smaller. Garm has a set mounted on his yaris.
and so a few waterpumps aren't perfect. That stinks, but there are always a few stupid problems with cars. Thank God the Yaris is one of the best in this category.
Colin Chapman disciple
Old 11-08-2010, 10:02 AM   #6
Idahotom
After hearing about guys who remove the windshield wipers for less drag, folding back the mirrors seemed pretty minor. A one time deal for me, though I do like how they hold their adjustment through the folding process. Maybe the next time I'm driving through Wyoming I'll do it again!
During that leg of the drive, I saw a state trooper had pulled over a Prius, and I had to wonder for what, too fast, too slow??? Drafting semi's maybe?
Old 11-08-2010, 12:09 PM   #7
why?
why?'s Avatar
Drives: Yaris LB
prius drivers are usually snobs who forget the rules apply to them as well.
Old 11-23-2010, 08:48 AM   #8
Midnight Drifter
Going Retro
Drives: '09 Tacoma | '90 Tercel
Oh, please. When I was coming home from Georgia, one of the fastest cars I drafted before the VA border was a Prius with the Virginia plate SAVN GRN. She averaged 95 mph and had a Greenpeace sticker on the back of her car.
...yeah, that's totally what you're supposed to do in a Prius. Floor it the whole way home to save gas.
Midnight Drifter is offline   Reply With Quote
Old 11-08-2010, 12:56 PM   #9
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
I would like ti see some smaller rear view mirrors that not only have less drag but generate less "wind noise"
Old 01-07-2011, 12:32 PM   #10
Prius bashing =
Old 01-07-2011, 11:26 PM   #11
cfeng
Drives: Yaris 2010 Liftback
i dont see how adjusting the mirrors will make a difference at normal driving speeds. sometimes drag is even beneficial. for example, the antennae, which seemingly produces unnecessary drag, helps to trip a turbulent boundary layer for higher efficiency and lower overall drag.
cfeng is offline   Reply With Quote
Old 01-08-2011, 12:08 PM   #12
Idahotom
What...you wind tunnel testing the Yaris with smoke streams or something?
The antenna is drag, though not much. As are the mirrors, less so when folded but who wants to drive around with no mirrors, besides me, one time!
Old 01-08-2011, 01:14 PM   #13
cfeng
i use a water tunnel in my lab. i've been thinking about this. with a properly designed rear wing on the hatchback, it may be possible to increase fuel economy.
the top picture is similar to a stock yaris, air swirls in vortex patterns, which means that not only does the yaris need to propel itself forward, but spend considerable energy into moving air. with the correct rear wing, there could be less separation in flow at end and less movement in the air, similar to the bottom picture. i found this picture online, the second picture is misleading because it represents an ideal case with virtually no separation in flow.
the antennae will disturb how the eddies are shed, reducing wasteful swirling of air (reduce a little). similarly, if a wing is designed to reduce the size and number of eddies from forming by increasing turbulence at the rear of the car, the car will have less drag and overall better efficiency.
Old 01-11-2011, 12:37 PM   #14
Yaristeve
Drives: 3-door hatch
Intersting drawings. What do you think (as in "do you think they work?") of those little "shark fin" vortex generators and Air Tabs? I was thinking of sticking on a row of the latter on the top of my hatch door but not on the sides as they recommend.
Old 01-12-2011, 04:09 AM   #15
cfeng
Its difficult to get something like this done right through trial and error. Unless if you have access to a full scale wind tunnel. I know that they are used on other cars already, I think one of the earlier evos had something similar.
The reason I was thinking about a wing is that it is larger and easier to test in the water tunnel at my lab. The job is the same, to trip turbulence that will be helpful in reducing drag. The equipment I use has lasers measuring the movement of small aluminum particles in water to visualize the flow on a computer. However, unless if the changes are drastic, this equipment probably wont accurately show the influence of tabs on a miniature yaris.
BTW, does anyone know where i can find a model yaris?
Old 01-08-2011, 04:13 PM   #16
derickveliz2
What about the Sedan?
D.
CLA 250, 4MATIC
Old 01-08-2011, 05:10 PM   #17
cfeng
can't say for sure. it would seem that a sedan will have separation in the back as well, however it may not be as defined. since the wing might help reduce the effects of separation, i'm not sure how much benefit you have if the separation is already less than the hatchback. however, i dont have much experience on aerodynamics of cars, i work on fish.
Old 01-09-2011, 07:41 PM   #18
sickpuppy1
Drives: 2010 Yaris Sedan
So are you creating more hydrodynamic fish? LOL
FS: not a car... 2004 600rr low miles (SoCal) AdeJong 03 Cars for Sale by private party 8 09-25-2009 12:13 PM
Clazzio Seat Covers at LOW LOW Prices!! Sparks Toyota-TRD Sponsors Classifieds Area 11 08-06-2009 05:02 PM
im looking for rota or drag rims dealer in toronto!!! marcus Cosmetic Modifications (Exterior/Interior) 15 05-27-2009 12:44 PM
CLAZZIO SEAT COVERS at LOW LOW Prices!! Sparks Toyota-TRD Sparks Toyota 1 04-02-2009 11:47 AM
Auto Shop Local Bay Area Genuine Toyota Parts Low Low Price with Warrenty YarisSedan California 1 10-31-2008 09:32 PM
